Question about D-Link AirPlus G DWL-G710 Wireless Range Extender
I want to get a password in my dap-1150 - D-Link AirPlus G DWL-G710 Wireless Range Extender
  • 781 Answers
When you say you want to get a password in your WAP I assume you want to enable security: there are 3 different ways to do it:
Enable WEP
(this is the most basic one and should be sufficient if you don't have a known hacker around your neighborhood and if you don't do transmit any critical information from your computer, ex. large and critical bank transactions.)
Step 1 Log into the web-basedconfiguration by opening up a web browser and typing in the IP addressof the access point (192.168.0.50).
Step 2 The default username is admin (all lower case) and the password is blank (nothing). Click OK.
Step 3 Click on the Home tab and then click Wireless on the left side.
Step 4 Click the Enabled radio button next to WEP.
Step 5 Next to WEP Encryption, select the level of encryption (64 or 128 bit).
Step 6 Next to Key Type, select HEX or ASCII. You will need to use the same key on all your wireless devices.
HEX - use 0-9 and A-F only.
ASCII - All numbers and letters.
Step 7 You can enter up to 4 different keys. Select the key you want to use by clicking on the corresponding radio button.
Step 8Enter your encryption key. You make this up yourself. If you selectedHEX, then enter a key made up of a combination of numbers (0-9) andletters (A-F). For example - A4572BCC19 (HEX).
Step 9 Click Apply to save settings.
Note:If you are configuring your access point from a wireless adapter, youwill lose connectivity as soon as you click Apply. You must enable WEPon your adapter and enter the same exact key as you entered on youraccess point.
Enable WPA-PSK (Passphrase) (this one is better than wep, this is the one currently suggested, it's not uncrackable but it's certainly harder than wep)
It is recommended to configure WPA-PSK on your wireless access point before your wireless network adapters.
Step 1Log into the web configuration of the DWL-G700AP by opening up a webbrowser and typing in the IP address of the Access Point(192.168.0.50).
Step 3 Click on the Home tab and then click Wireless on the left hand side.
Step 4 Next to Authentication select WPA-PSK using the radio buttons.
Step 5Enter a Passphrase. The passphrase or key is an alpha-numeric passwordbetween 8 and 63 characters long. It can include symbols (!?*&_)and spaces. Make sure you enter this key exactly the same on all otherwireless clients.
Step 6 Click on the Apply button then click on the Continue button to save your settings.
Make sure you enter the same exact WPA-PSK Passphrase on your wireless clients.
Enable WPA (RADIUS)
It is recommended to configure WPA on your wireless access point before your wireless network adapters.
Step 4 Next to Authentication select WPA using the radio buttons.
Step 5 Under 802.1X enter the IP Address, Port and Secret Key for RADIUS Server 1. Repeat for RADIUS Server 2 if applicable.
Step 6 Click Apply and then Continue to save the settings.
the following one is to make sure only those who know the name of your router (SSID) can access it. it's not setting up a password but it's another level of security
Disable SSID Broadcast
Step 1 Open your web browsersuch as Internet Explorer and enter the IP address of the DWL-G700AP inthe Address bar and press Enter. The default IP address is192.168.0.50.
Step 2 Enter your username (admin) and your password (leave blank by default). Click OK.
Step 3 Select the Advanced tab and then click Performance on the left side.
Step 4 Next to SSID Broadcast, select the Disabled radio button.
Step 5 Click Apply to save your settings.
the next one, as the one before. it's not a setting a password but to make sure only those network adapters you have or know can access your router, it's another level of security
MAC Address Filtering
Step 1 Open your web browserand type the IP address of the access point in the address bar. Thedefault IP address is 192.168.0.50. At the login, enter your username(admin) and password (default password is blank). Click OK
Step 2 Click the Advanced tab and then click Filters on the left side.
Step 3 In the section MAC Filters, select the radio button for the mode you would like to use.
Disabled - Disables this feature and will allow all wireless clients to connect.
Allow - Blocks all clients except for what you enter in the list.
Deny - Allows all clients except for what you enter in the list.
Step 4 Enter the Ethernet MAC address that you wish to Allow or Deny.
Step 5 Click Apply and then click Continue to save your settings.
Posted on Nov 17, 2009
How can I assign IP of my access point Dlink DAP-1150 on my lap top. I want to add adapter network DAP-1150 on my pc
there are 3 ways of setting it up as an Access Point, Wireless Client, Wireless Repeater mode. Would be easier if you explain what you want to use it as?
Choose what you want to use it as, you can set it up plugged into the router or over the wireless , so just plug it into your router and follow the instructions in the manual, you will then be able to unplug it and it will automatically connect to the router over the wifi. manual can be found here ftp://ftp.dlinkla.com/pub/drivers/DAP-1150/DAP-1150_A1_Manual_1.10%28B%29.pdf
Jul 12, 2014 | Samsung R540 Laptop
How to assign static IP of my access point DAP 1150 to my pc
From your computer, get the MAC-address of your network adapter.
Configure the router to always give out the same IP-address for that MAC-address.
Jul 12, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
Dlinkap
You can do a reset to default settings. OR using the on-line setup, change/remove Security Key, refer to the User Manual here: http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201522/Manual/DAP%201522_Manual_EN_US.pdf
May 16, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
I configure a DAP-1150 and can connect via a laptop but my iphone and ipad fail to connect it. However, when I reset the DAP (with no security), the opposite happens! It means that my iphone and ipad can...
That is because your laptop has the saved connection history that you need to delete. Since your acces point does not have security which is not the same as the one that saved from your laptop. Therefore, your laptop won't be able to connect. Go to network and sharing center and from the left side of the page that came up look for change wireless adapter settings and click it. You will be able to see the connections that was saved and the top one would be your connection name. Delete that and close everything. Try connecting to your wireless network again and that should resolve the issue.
Feb 06, 2013 | D-Link DAP-1150 802.11g Wireless Access...
I cannot configure the DLink DAP 1150 access point .As said in the manual When I put the user name and start it says that password is not valid.what is the solution?
Reset the device, unplug all network cable before power on (to turn off dhcp function). After that connect the network cablethe ip device should 192.168.0.50 and subnet mask 255.255.255.0. Set your computer ip address to 192.168.0.xxx where xxx is not 50. Access the device via your web browser, the login page should be apear. User : admin, password : leave it blank
Jan 06, 2010 | Computers & Internet
Can't open DAP-1150 configuration utility
The DLink URL WEB configuration uses an IP address not //dlinkap
Try http://192.168.0.1
The default ligin = admin
The default PW = blank ie. nothing
Jan 04, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
I have already installed my DAP-1150. Now how to make it security enabled?
open your internet explorer and type into the address 192.168.0.1 then enter, A box will pop up, at this point either enter your password and username, or (if you have none yet) type Admin for user name and press enter. You can use the wizard to guide you thru the setup at this point. This will help you setup everything including your WEP security.
Hope this helps
Oct 06, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
Configuration dap 1150
You cannot configure the DLink by the URL address http://dlinkap?
You connect a LAN cable from your computer to the DLink.
Then open Internet Explorer and enter the URL http://192.168.0.1
the default login = admin
the PW is blank (just press Enter)
You can now configure the DLink.
Sep 28, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
Configuring DAP-1150
address to access d-link DAP-1150
http://192.168.0.50
you have to make sure that your ip address is around 192.168.0.xx
Apr 25, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
D-Link AirPlus G DWL-G710 Wireless Range Extender Logo
1,329 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
