Question about Roper REX4634KQ Electric Dryer
My roper dryer will not dry all the clothes in one cycle.
    Sergeant:
    Champion:
  • 289 Answers
Try runing your dryer with out the vent hose.if your dryer wooks well than you have a problem from were the vent hose hooks up to your dryer and the outside vent.
Posted on Dec 29, 2009
Roper dryer red4440vq1 not drying after changing internal fuse, internal bias, high limit thermostat and thermal cut off and cleaning vent, element heats up to temp and cycles
If heater is heating and not drying clothes, you have a blockage in ventilation system somewhere either internally in dryer or going out from dryer to outside. Take vent off back of dryer and turn on. Is air flow strong and hot?
Sep 15, 2017 | Roper Dryers
Whirlpool dryer does not get hot enough to dry clothes.
Clean/repair the dryer vent. If the airflow is restricted the result is the one you just described.
Good luck,
Vlad
First Choice Appliance
Apr 20, 2010 | Roper REX4634KQ Electric Dryer
Takes 2 cycles on high to dry cloths. i hooked osiloscope up to it and it will draw 22.5 amps for about 25 seconds and bounce between 2 and 7 amps for about 90 seconds and keep repeating this way (on high...
Hello. Generally, when clothes take a long time to dry the problem is excessive lint in the exhaust pipe. pull the dryer out from the wall, disconnect the vent pipe and remove lint going to the outdoors and also back inside of the dryer. Regards, joe
Dec 07, 2009 | Roper RES7648E Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Dryer has some heat but is taking a long time to dry clothes
This type of problem can be caused by a partially burnt heating element, a blown thermal fuse, or a faulty high limit thermostat. All of these components can be checked using an ohm meter or multimeter. Sure hope this helped and best wishes.
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
My roper REX3514 Dryer will only dry on the time cycle.
If you use a lot of dryer sheets, it will build up an oily residue on the sensor strips causing a "false" reading. Light sandpaper and alchohol over the strips should clean them well. Another possibility, is if you have a mixed load, ie..towels, socks, jeans , if a sock or something light keeps hitting the strips, the dryer thinks the whole load is dry (it doesn't know there are different thing in there) Try keeping loads similar when using auto dry.
Mar 14, 2009 | Roper REX3614KW Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Roper REX4634KQ Electric Dryer Logo
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
