Question about Mitsubishi WS-65611 65" Rear Projection Television
Reset swich is pushed and it blinks sevral times no pic no sound
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
THIS IS MY STANDARD ANSWER TO THIS QUESTION==SOMETIMES PEOPLE DO NOT TRY THE EASY POSSIBLE REASON--IF YOU HAVE ANY QUESTIONS LET ME KNOW---IF THE ANSWER TOLD YOU something you did not know--rate the solution----
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
SD TECH
Posted on Nov 17, 2009
Sony kp53hs standby light blinking 6 times
do you have the HS 10, HS20 or HS30 model number with the 6 blinks?
Apr 04, 2012 | Sony Televison & Video
My nokia blinks 3 times and thn swiches off plz help me wat i can do nw?
dear friend,
this may be due to software problem ...you can do one thing reset your phone that may help do vote to know the reset code
enjoy & cheers
Jan 16, 2011 | Nokia 3110 Cellular Phone
How to set the clock of sigma bc 1009 sts
hold the left bottom button untill the blinking caption "settings/ open" disappears. Then there are some options: language, distance counter, wheel size and clock. Swich between them with right bottom button, and when clock appears push the left bottom and change hour with top buttons, swich to minutes with the right bottom and finish by pushing the left bottom button. Then hold it longer to exit settings. Done. Damn, I could find no online manual and had to discover that myself.
Nov 01, 2010 | Cycling
Panasonic model th42pz77u no pic, no sound, blinking red light ten times
9.2. Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
26
TH-42PZ77U:
There are different patterns for blinking light...
10 times indicate DG board problem - SUB 5V SOS, MAIN 3.3V SOS, DTV 9V SOS and Tuner Power SOS.
Aug 16, 2010 | Panasonic TH-42PZ77U TV
Hi, i have a bmw cd changer that keeps bringing a no disk error m
Remove changer, check fuse located on rear of changer +connections.Also check for water ingress.Common problem, good luck.
Sep 27, 2009 | 2003 Land Rover Range Rover
60 in sony grand wega
if it turns to red most likely you need to replace the bulb.
Larry D
Aug 15, 2009 | Televison & Video
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
No pic no sound...
no sir. reset wont solve this problem at all
you will have to do a replacement of the vertical ICs
get it done as soon as possible
Jul 30, 2008 | Philips 32PT9100D 32" TV
Mitsubishi WS-65611 65" Rear Projection Television Logo
103 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
