Question about Whirlpool Accubake RF362LXTT Electric Kitchen Range
How do you change element on Whirlpool gold accubake oven. I have 2 elements that need replaceing
  • 725 Answers
This is one of the most simple repairs you can make. First turn the breaker off to the unit. Some models are just wired in with two wires and some models have clips that just snap in and out.
We are Whirlpool factory authorized service and parts supplier so contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 Am until 9 PM CST for all your parts needs.
We want to get you c ooking again ASAP!
We ship overnight to our customers. Thanks, Ella
Posted on Nov 17, 2009
Error message E6 F2
From investigation, I would open the control panel (make sure the power is turned off first!) Look for a ribbon cable that goes to the Touch Pad and Control pad module. It should be able to be removed from the control board. Pull out the ribbon cable, and put the ribbon cable back into the connector. Be careful with the cable as they can be broken easily. Once you have everything back together, turn the power back on and test the pad. If it still doesn't work, the control board may be bad.
Nov 05, 2013 | Whirlpool Gold Resource Saver GGE390LX 30"...
Whirlpool Gold Accubake System smooth top stove keeps kicking out the 10 amp breaker, sometimes with oven on, sometimes just a burner on, just started doing this a week ago, why????
I have had teh same issue. Not sure if its a design issue or that is just how it works. I have replaced the element, the thermostat and the control board and it still does the repeated cycling.
Aug 30, 2010 | Whirlpool Kitchen Ranges
The bottom element on my Whirlpool Gold Self-cleaning Accubake system (purchased in 1999) is not working. What is wrong?
Hi, Are you equipped to check the bake element to determine if it's the problem ? You may be able to see if it has a burnt section on the element via a visual inspection. If so it is the problem, if not you'll need a multimeter or a pro technician to come and inspect it. With a meter you want to check the element for continuity (unplug the range and remove one of the wires at the element first) I will add the price of a bake element is cheaper than phoning for service "IF" you can change it yourself. Hope that help's you at least reach a place to make an informed descision on whether to attempt a repair on your own or call a pro. Thank's for visiting fixya. Please take a second to rate the info I provided for you today. Good luck in whichever way you choose. Macmarkus :)
Dec 11, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
My whirlpool gold accubake system-oven is not heating right. about a few weeks back I saw the bake element spark and thought it was no problem, but I guess I was wrong. Did I fry the bake element or is...
yes if you turn the oven on bake that element should heat pretty quick, if not its toast..
if i had a model # i could be more specific but generally all you'd need to do is turn off the breaker or unplug the unit.
remove the screws that hold it to the rear of the cabinet, and slide the element straight back towards the front enough to expose the screw or slide on connectors.
now you can either remove 1 wire at a time and have the new element sitting under the old one and transfer then as you go, or remove 1 wire and bend if over some so it won't slide back into the unit and get lost..
after the wires are reconnected slide the element back into place and replace the screws and restore power and cook..
hope this helps,
best of luck,
ttfn
Oct 29, 2009 | Ovens
Whirlpool Electric Cook top Coil
there may be 2 screws on the rear/behind of the cooker top or on the front underneath the top when top oven door is open.
Sep 30, 2009 | Hotpoint RGB745 Gas Kitchen Range
Whirlpool gold accubake GJP84802
If you can gain access to the clock you could find the wires that goes to the bake element - if you can measure and confirm the resistance of the element chances you may have also fried the relay of the board - check it out
Regards
Sep 06, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool Accubake RF362LXTT Electric Kitchen Range Logo
703 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
