Question about Jenny Products Inc AM780-HC2 1.5 Gallon Tank 2 HP Electric Hand Carry Portable Air Compressor
What grade oil doI use to change the oil? - Jenny Products Inc AM780-HC2 1.5 Gallon Tank 2 HP Electric Hand Carry Portable Air Compressor
  • 530 Answers
Your comressor comes from the factory filled with Jenny Synthetic Blue Compressor Pump Oil. This is a 30 weight oil.
The picture below is Ingersoll Rands version of this oil.
I use it and have no complaints about it. It's also a lot easier to get.
That said any 30 weight oil will work. Although I would recommend synthetic because that is what the motor was broke in with.
Hope this helps.
Posted on Nov 17, 2009
  • 317 Answers
Compressor oil....lowes or home depot
How often should I change my 454's oil?
Go with the schedule oil change as listed in the hand book. Otherwise 10.000 klm or 6 months . Change at 5000klm if difficult conditions. Type of oil Conditions dictate if you use a multi grade 10/15w- 20/30/40/50 grade oil Again check the hand book Mineral oil will do just a good a job as the more expensive synthentic types As to brands that is you choice.
Mar 10, 2013 | Cars & Trucks
How do I change the timing so I can use different grade of gas and not get the knocking?
NOT SURE WHY SOMEONE TOLD YOU THIS? BUT YOU HAVE A RANGE FOR YOUR TIMING HAVE TO CHECK SPECS BUT THAT HAS NOTHING TO DO WITH GASOLINE GRADE YOUR HEARING KNOCKING YOUR VALVES COULD BE GETTING SMUDGED AND GUNKED UP I RECOMMEND CHANGING OIL RUNNING A BOTTLE OF LUCAS OIL STABILIZER WITH OIL REPLACES ONE QUART ALSO LUCAS FUEL INJECTOR CLEANER 3OZ TO EVERY TEN GALLONS OF GAS YOU CAN DO THIS WITH 87 GRADE KEEP TIRES INFLATED PROPERLY FRONT END ALIGNMENT PROPER OIL THESE ARE ALL FUEL SAVING TECHNIQUES THAT WORK!
May 09, 2012 | 2000 Dodge Durango
What grade oil do I use to change out on my Chicago Pneumatic RPC-561VNS? The manual says a compressor grade non-deturgent oil should be used, but does no specify a grade.
Hi and welcome to FixYa, I am Kelly.
Compressor grade oils are basically SAE30 W oil. Read this:
Rol-Air OILCOMP30W34C Air Compressor Pump Oil - 30W Quart features ,
Specially engineered and tested to match the requirements of Rol-Air air
compressors , Provides superior rust and corrosion protection.
I.e SAE 30W oil / the same thing you would use in an older lawn mower engine or generator.
What they don't tell you is because they have re-labeled the 30W oil to OILCOMP30W they can charge you big time for SAE 30W oil. The only difference is the label.
Thanks for choosing FixYa,
Kelly
Sep 22, 2011 | Chicago Pneumatic 60Gallon TwoStage Air...
How much oil should I put in when I change the oil?
The bike holds just around 3 qts of oil Yamaha says use 20w40 but should be fine with any high grade motor oil all though I suggest not using anything with additives in it just basic high grade oil.
Jun 21, 2011 | 1981 Yamaha XJ 650
Hello what is the capacity oil of honda xr 250 model 2005
The oil capacity of an XR250R / L is 1.3 litres if you are only changing oil.
If you are changing oil and filter you need 1.4 litres.
The oil type should be API grade SF or SG multi-grade oil for motorcycles.
Viscosity 10W-40 as standard but 10W-30 ,20W-40 or 20W-50 are acceptable dependent on the temperatures where you live, your supplier can advise on this.
May 16, 2011 | 1998 Honda XR 250 R
What grade of oil doe a 2007 Suzuki Reno take. 5 30 or 10 30
Suzuki recommends 10w30 grade oil and it will need about 2.4 quarts of oil without a filter change and 2.6 with a filter change.
Dec 19, 2010 | 2007 Suzuki Reno Hatchback
How often do you change the motor oil? The motor oil filter? The automatic transmission oil and filter? What type of motor oil should be used?
Oil change recommended is every 3,000miles / 5000km for local short running around. If you clock up the miles quickly then extend the oil changes to 6,000miles /10,000km
Oil filter is every second oil change.
Use reputable multi grade oil 15W/40 or similar, Do not use standard SAE 30 single grade oil. You do not need to use synthetic / semi-synthetic oils either.
Oct 20, 2010 | 2002 Nissan Maxima
Oil type for 2006 dodge grand caravan
New cars and truck manufactures recomend differend types of grades of oil when the engine is new. What they don't tell you when the engine receives 30,000 miles on it the grade of oil can be changed for better lubrication. Use 10w30 for normal use upon changing oil.
Jul 05, 2010 | 2006 Dodge Grand Caravan
Oil capacity & recommended grade for 2004 yamaha xvs1100 v star classic
hi buddy the oil reccomended/grade 5w-40 i recomend using silkolene pro 4 plus 5w-40 AND ADD 3.6LITRES WITH OIL FILTER CHANGED OR 3.1LITRES WITH STANDARD CHANGE
Oct 02, 2009 | 2004 Yamaha V Star Classic
Jenny Products Inc AM780-HC2 1.5 Gallon Tank 2 HP Electric Hand Carry Portable Air Compressor Logo
200 people viewed this question
Top Jenny Products Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Jenny Products Air Tool and Compressor Expert? Answer questions, earn points and help others
