How much water to add to Westinghouse frontloader?
We moved house and cannot find the manual for our Westinghouse front loader washing machine, model LF652D. We drained the water before moving it, and I remember the manual said you have to add water to it before you first start it - but how much water? Does anyone know? I am afraid that I'll wreck it if I add too much or too little...
  • 725 Answers
If you add too much, it will just drain until it reaches the correct amount to start.
Hope this answers your questions.
Posted on Nov 17, 2009
I have a Westinghouse front loader 708 it starts to fill not much water goes in then it try's to wash and comes up with a Ce error
Consult the owner's manual--usually the Troubleshooting section. Or search internet for the Make + Model + the word "Ce"
Mar 05, 2016 | Westinghouse Washing Machines
Ytek.netwe just moved into a house with a duet washing machine- a few years old. when we do a normal clean cycle, it doesnt appear there is that much water getting used. How much water should we see thru...
All front loaders use very little water as a opposed to a top loader that uses up to 45 gallons per load a front loader uses about 10,plus a front loader cleans clothes very well with that minimal water usage.
The major question is do the clothes seem to come out clean when you have used that washer?
Aug 20, 2011 | Whirlpool Washing Machines
My daughter has moved into a rental house with a very small Whirlpool front loader. There is no model number or manual, and her email is not working. She would like to wash in cold water as is our...
delicate is typically always only cold
the other 2 are usually warm
if you could reach the faucets where the hoses attach to you could turn off the hot water faucet assuring it would only had cold water going into it
Gene
Aug 11, 2011 | Whirlpool LHW0050PQ Front Load Washer
Washer leaking from underneath
MY FIRST THOUGHT WOULD BE INSPECT THE BIG GREY DOOR GASKET FOR A CUT OR A TEAR. LOOK CLOSE. THE WHOLE MAY BE TINY
LEVI
LEBARCHRIGEN APPLIANCE REPAIR
WWW.LARTODAY.COM
Dec 11, 2009 | Westinghouse Washing Machines
My washer doesn't get enough water in it to wash properally.There isn't a water level knob on the washer.Its a frontloading whirlpool.
There is most likely nothing wrong with the washer. Front load washers will only fill about 2 inches of water in the tub. As the load starts to tumble, water is absorbed into the clothes, causing the water level to drop. The machine senses this and adds more water. The process continues until the water level stabilizes. (thus no need for a water level switch) Your clothes should get wet, but you will little if any water. If you use a gentle cycle you will get slightly more water, as the washers tumble at the same speed for all cycles, but give a more gentile wash if there is more water in the drum.
Also,..... remember because you have so little water in a front load washer (compared to most all top loader models) you want to use only 1 to 2 (max) tablespoons of HE detergent per load!
Aug 27, 2008 | Washing Machines
Washing machine dosnt spin dry, front loader westinghouse mastermind 708, 7.5 kg
remove the front panel and check for obstructions in the drain pump also on some models there is a catch screen in the tub to pump hose if you have a shop vac pull the water out of the drain hose first as there will be water in the unit
Jun 03, 2008 | Washing Machines
Asko front load washing machine
When u use front loaders you normally don't need a soak. And i don't think you need bleach. Use front loading powders for the machine. The automatic machine is supposed to work for you. The water empties out, so you can open the door.
Rate me pl if helped..............
Jan 24, 2008 | Asko W6221 Front Load Washer
Washing Machines Logo
106 people viewed this question
Top Washing Machines Experts
