Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
The pitchure looks like its 3d. everything looks
The pitchure looks like its 3d. everything looks red and blue.
    Brigadier General:
  • 4,090 Answers
You have a convergece board failure. Changing one board will not nescessarily fix it. It is recommended to change all 3 boards in the unit. many try this as a DIY and fall afoul because it is a specialist job to retune and reset the paramaters. The cost then becomes greater than if a tech did it correctly the first time. Be advised it is not a simple DIY.It requires soldering and desoldering skills, specialised tools and a knowledge of circuit diagrams.
Please rate my help++++Thanks for using FIXYA
Posted on Nov 17, 2009
Testimonial: "thank you very much. i thought it was just replaceing a bulb or something. do you know what it may cost to have this fixed or should i buy new"
  • dennis bullard Nov 20, 2009
    Ronald It would only be a guess, as i am in Australia and costs differ But generally from others that have commented it costs $300 in parts in USA + labour But generally having it done for you is a better investment from the stats on this forum Best wishes dennis
  • Sony Master
  • 3,459 Answers
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
the pitchure looks like its 3d.  everything looks - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Nov 28, 2009
I just got this hitachi and the pitchure is off I dont have the remote control and I cant get it to line up with the colors
IF PICTURE LOOKS 3D OR HAS RED OR BLUE AROUND LETTERS IT IS A CONVERGENCE PROBLEM.
PARTS COST TO FIX IF THIS IS UNDER 30 DOLLARS.
DO YOU HAVE QUESTIONS?
Sep 18, 2010 | Hitachi 57SWX20B 57" Rear Projection...
The tv looks 3d and doubles red and blue and greem
Sounds like a convergence failure. Here is my tutorial, let me know if you have other questions
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Jun 22, 2010 | Samsung HCL4715W 47" Rear Projection...
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
The TV is showing everything in a 3D kind of way. Everthing looks like a 3D proection, with only red and blue overlapping at some points.
Try to use a convergence function found in the menu. If that doesn't work clean the lenses with alcohol and q-tips. Good luck.
Mar 14, 2010 | Sony KP-48S65 48" Rear Projection...
Pic looks like 3d
Convergence chip and capacitors damaged on the Y sustain board Cant be tuned from the unit controls
Oct 24, 2009 | RCA R52WH73 Projection Television
The colors are distorted and it seems like the only colors that really show are blue, green, and red. When you turn the TV on you can see blue, green, and red lines across the screen. The picture also...
Hi there, this is what we call in the industry convergence board failure. this board regulate the rgb and keeps everything in order so the picture looks nice and clean. when this board starts to malfunction, what you are witnessing is usually the result. I suggest repairing this convergence board. this will fix the 3-d effect.
Mar 08, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Everything works but looks animated with green and red
Sounds like a classic case of a convergence problem. If you give me a model number and a manufacture i can help your further.
Thanks
Tim Nolan
Sep 24, 2008 | Televison & Video
Red color border on the pitchures
Probably the convergence output integrated circuit is at fault. There are two-one for red and one for blue. They should both be changed. Also, sometimes the resistors feeding the I.C. may have opened as well.
Mar 01, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60 rear projection hdtv looks 3D
If your red convergence controls will not remove the red in all four directions, you have a faulty convergence IC. You will need to replace both. They cost around ten dollars each. Let me know if you need anything further.
Feb 02, 2008 | Televison & Video
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
175 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
