Question about Gateway (1532852) Power Supply
The ac adapter is not working for my gateway laptop any ideas?
    Brigadier General:
  • 4,090 Answers
Is the green/red light lit? If you have a multimeter check the plug end to see if there is voltage flowing.
Other than that you can purchase a new power pack online through ebay or the Gateway site online.
cost about $45-50
Ple4ase rate my help++++Thanks for using fixya
Posted on Nov 17, 2009
Will not power on
MPC has since dissolved, leaving thousands of customers without dedicated support when their Gateway laptop won't start.
Remove the AC adapter from the laptop and attempt to boot the laptop from battery alone. Attempt to turn on the laptop.
Replace the AC adapter and remove the battery from your laptop.
Ensure the adapter is plugged in. Attempt to turn on the laptop.
Disconnect the AC adapter and leave the battery removed from the laptop.
Hold down the power button for 30 seconds.
Nothing should happen on the screen.
Reconnect the AC adapter to the laptop.
Attempt to power on the laptop.
If the laptop boots, replace the battery once the operating system loads.
Try the process again with a new AC adapter and battery if possible.
Contact Gateway support if you aren't a former MPC customer.
Alternatively, take the laptop to a computer specialist if it still won't start.
Nov 19, 2013 | Gateway 17.3" NE71B06u Laptop PC with AMD...
Why won't my gateway MD78 power on?
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Gateway MD78 AC Adapter 65Watt 19V 3.42A Option
Replacement Gateway MD78 MD7800 AC Adapter 90Watt 19V 4.74A
Nov 29, 2012 | Gateway Computers & Internet
I got a new battery it worked when i got it now it wont charge ac adapter works though after i made sure the battery worked i put the computer away for a present for my daughter i have my own laptop so the...
Welcome to FixYa!
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jul 17, 2011 | Gateway T-6321 PC Notebook
I've had my Gateway M-6843 Notebook for about 18 months. Since the day I bought it from Best Buy, the AC adapter port has been finicky. I'll be using the laptop with the adapter plugged in and the...
This problem can be caused by mainly two different things. It is either the AC Adapter itself and has a short in it, or sometimes it is caused by the Power Jack inside the laptop. Are you familiar with how to read a voltmeter? I can walk you through testing your adapter. If it is either issue, I would recommend trying to fix through warranty if possible, because the power jack repair can be expensive. If you need to replace the AC adapter, I recommend a genuine adapter, as universal adapters and cheap knockoff brands will cause issues with your laptop and usually not last very long.
Dec 11, 2009 | Gateway M-6843 Notebook
Gateway MX6428 Power Problem
faulty wiring in the wall (hopefully not) or the AC adapter try another adapter or outlet
Aug 12, 2009 | Gateway MX6428 Notebook
I have a Gateway 4525GZ power problem
your ac adoptor is not correct it is low amh
please check for original adoptor
Jul 30, 2009 | Gateway 4525GZ Notebook
Gateway 7330gz Laptop Won't Charge
Could be your connection inside the laptop itself.
They tend to go easily in gateways.
The wear and tear from plugging it in and out.
Cost approximately $70.00 - $100.00 to repair.
Can usually get the best price at a small computer repair store
Jan 12, 2009 | Gateway 7330GZ Notebook
Battery won't charge.
battery could be dead,standard life for laptops is 1 year
Jun 26, 2008 | Gateway 450ROG Notebook
GATEWAY AC/DC ADAPTER
just tap in adapters in your serch engine and there are many places you can get them cheap off the internet lala linda
Jun 08, 2008 | Televison & Video
Gateway (1532852) Power Supply Logo
117 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
