Alert Driveway Patrol Infrared Wireless System Logo
Posted on Nov 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ALARM SOUND ABOUT EVERY 5 SECONDS AND i HAVE NOT YET PUT IT OUTSIDE
Big_Lebowski
Level 2:
Scholar:
  • Expert 108 Answers
  • Posted on Nov 17, 2009
Big_Lebowski
Expert
Level 2:
Scholar:
Answers
108
Questions
0
Helped
27406
Points
283
Check the instruction, it sounds like you are getng interferance on the channel its on. the instructions should cover changing it to another channel and avoiding something else triggering it.
  • Big_Lebowski Nov 19, 2009
    Wow, thanks for the one thumb review. had you already tried this?. Or what?...
My watch is 3 hours and 5 minutes off its a shp8948
1. Since all of the settings seem to go through the start/stop button, hold it down for three seconds to put it in "set the watch mode" (when the seconds at the bottom start blinking).
2. Do a quick press of the start/stop button to move from seconds to minutes to hours to years to months to days. The mode button subtracts & the reset button adds.
3. Setting alarms & so on require putting it alarm mode via the mode button. Use the reset button to move to the selected alarm (1-5).
4. Hold the start/stop button for three seconds to "set the alarm mode."
5. Quickly press the start/stop button to between things to set (kind of alarm, hours, minutes).
6. Again, the mode button subtracts & the reset button adds.
7. A three-second press of the start/stop button exits the setup mode.
Feb 27, 2015 • Watches
Instructions
From the manual:
Setting the Clock
1. Press and hold the Time Set Button until the display begins flashing
2. Press the Reverse or Forward Button to set the time. Holding a button for a few seconds will advance or reverse the time rapidly. Set the correct AM/PM time, shown by the PM Indicator on the display
3. After setting the time, press the Enter Button or wait about ten seconds for the unit to beep twice and the display to return to the normal mode
Setting the Calendar (It is important to set the correct date in order to use the 7-5-2 Alarm settings)
1. Press and hold the Date Set/7-5-2 Button until the display flashes and the year replaces the month/day at the bottom of the display
2. Press the Reverse or Forward Button to set the correct year, and then press the Enter Button. The unit will beep and the display will show the month and day. Again, press the Reverse or Forward
Button to set the current date
3. After setting the date, press the Enter Button or wait ten seconds to return to the normal display mode
Setting the AM/FM Radio Alarm
1. Press and hold the Radio Alarm Button until the settings and radio frequency appear on the display.
2. Press the Reverse or Forward Button to set the alarm time.
3. Use the AM/FM Band Button or the Memory Set 1-6 Buttons to select a radio station to wake up to. Adjust the alarm volume using the Volume Thumbwheel
4. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
5. After you have programmed the radio alarm, press the Enter Button or wait ten seconds to return to the clock display. The Radio Alarm Indicator will appear on the display, showing that the alarm is set.
Setting the Nature Sounds Alarm
1. Press and hold the Sounds Alarm Button until the settings and Nature Sounds Indicator appear
3. Use the Nature Sounds Button to select a nature sound to wake to. There is a choice of four sounds:
Sound #1: Ocean Surf
Sound #2: Forest Spring
Sound #3: Rushing Brook
Sound #4: Summer Wind
5. After you have programmed the nature sounds alarm, press the Enter Button or wait ten seconds to return to the clock display. The Nature Sounds Alarm Indicator will appear on the display.
Setting the Buzzer Alarm
1. Press and hold theBuzzer Alarm Buttonuntil the alarm setting appears on the display.
3. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
4. After you have programmed the buzzer alarm, press the Enter Button or wait ten seconds to return to the clock display. The Buzzer Alarm Indicator will appear on the display, showing that the alarm is set.
2helpful
The fire alarm in the master bedroom is beeping for every 5 seconds.. wat to do
Sounds to me like your 9 volt battery is dead. I just went through the same thing and I put new 9 volt battery in it. Problem solved.
1helpful
How do i set my alarm and when do i know it is on or off....keeps coming on and i dont know how to shut off the alarm...thank you
This clock radio features a dual alarm system, with two separate alarms that can be operated independently. The alarms can be set to wake two people at different times, or to have a main alarm and a backup. One alarm features your choice of radio stations as an alarm wake sound, while the second features a buzzer wake sound. You can set the radio alarm, the buzzer alarm, or both alarms.
Setting Radio Alarm
1. Press the "Alarm Set" Button. The display will flash and the Radio Alarm Indicator will appear. If you do not begin setting the time within ten seconds of pressing the it, the display will stop flashing andd you will need to press the "alarm Set Button again. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time. Hold a button for a few seconds to advance the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator. 3. After setting the radio alarm time, you will need to select the station to wake up to. First, press the "AM/FM" Button to select a radio frequency. Next, select a station using the "Radio Preset Buttons". Rotate the Volume Thumbwheel to set a wake sound volume level. 4. After setting the radio alarm wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date is set. 5. After you have set the radio alarm wake time, wake sound, and 7-5-2 setting, press the "Alarm Set" Button twice so that the display shows the standard, non-flashing display.
Setting Buzzer Alarm
1. Press the "Alarm Set" Button twice. The display will flash and the Buzzer Alarm Indicator will appear. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time, as described above. 3. After setting the buzzer wake time, use the "Date/7-5-2" Button to select the buzzer. 4. After you have set the buzzer wake time and 7-5-2 setting, press the "Alarm Set" Button once so that the display shows the standard, non- flashing display.
Activating the Alarms
1. To activate the radio alarm, press the "Radio Alarm" Button so that the Radio Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 2. To activate the buzzer alarm, press the "Buzzer Alarm" Button so that the Buzzer Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 3. When the alarm sounds, press the " Off/Reset" Button to turn off the alarm while still maintaining the programmed 7-5-2 alarm settings. To turn off an alarm and cancel its 7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on the display. 4. To activate the snooze feature, press the "Snooze/Night-Light" Bar when the alarm sounds. The alarm will shut off for approximately nine minutes before sounding again. The feature can be repeated several times during the one-hour snooze cycle. 5. If it is not turned off, the alarm will sound for an hour before stopping. As long as an Alarm Indicator appears on the display, the alarm will sound at the set time, according to the 7-5-2 settings.
We understand that your problem is: My 95 jeep
Have it towed to a car alarm specialist that is familar with Chrysler products. With a little luck they can fix it.. To reset alarm
(if it will work}, try locking drivers door and unlock it with the remote from outside.
The 5 second thing does not sound good.. Usually this locks your ECM out so it will never start. Thinks someone is trying to steal it.
I bought a Chevy Trailblazer, used, had keyless remote access Viper Alarm after manufacturer. Had trouble with transmission and alarm....took to Chevy dealer they replaced transmission. Now the remote...
You need to find the black push button called the valet button. That is the overide. Get in the car turn the key to IGN as the alarm is going off and then you have either 5 or 10 seconds to push that button once and then 2-5 seconds later the alarm is shut off. To put the car into valet mode which means no alarm at all you put the key to IGN push that button once then pull key out at which point the blue light should turn solid blue.
Or option two is you open a door and hit the lock, then unlock, then lock button again on the remote and the blue led will be solid which means no crazy alarm.
1helpful
How do I change the radio station on the radio alarm
Here is the full manual
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Here are the instructions from the manual.
Setting the Radio Alarm
Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
flashing and you will need to press the
Radio Alarm Button again.
2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
information on programming radio stations into memory, see the Programming Radio Station Settings section
of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
While the display is still flashing, press the  Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
12helpful
Lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
Indicator
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
1helpful
Alarm setting
The alarm sounds for only 5 seconds.When you receive a fax and the paper jams, the fax will be received into memory. When it has finished receiving the fax, the alarm will sound momentarily. When you remove the jammed paper, the fax will print automatically.
Top Alert Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you an Alert Home Security Expert? Answer questions, earn points and help others
