Connection I lost the paper that shows how to hook it up to the tv please help
  • 317 Answers
Here is a diagram of a simple hookup, if you need more just let me know
What ARe you connecting to the TV?
Posted on Jan 10, 2008
Alba lcd32880hdf has lost colour when watching Tv but works when using games console
It is almost for sure a bad connection at you wires. To show in black and white means your red and green are reversed or bad. I am guessing you have this hooked up with component.
Jan 27, 2014 | Televison & Video
1) I can't get a picture on my tv 2) color code for wireless
have you tried unplugging the TV for 3 minutes, then plugging it back in???
Oct 06, 2012 | Televison & Video
I cannot get the YPbPr to work on my TV. I have a PlayStation 3 hooked up to it yet it still will not show it on the TV. Now the Playstation WILL show up on HDMI, but also can be used with component...
If you are using component connection for your playstation, you need to change the resolution from 1080p to 720p on the system. It will not work otherwise.
Jul 06, 2011 | Bush Televison & Video
LG 42LG50 42 in. HDTV LCD TV just hooked digital box to tv , and signal is lost after a while. picture shows audio lost, please help.
Reset ur tv by unplug,replug it an hour later.Do the same with the digital box.Go to ur tv menu.Go to AUDIO setting,go down to reset,ur audio should return to factory setting,should have sound return.
May 04, 2010 | LG 42LG50 42 in. LCD HDTV
We have an older tv with an indoor vhf/uhf antenna. We have hooked up the converter box according to directions and even watched a video showing how to hook it up. However, with the tc on channel 3 and...
Sounds like a connection problem, if coaxial connection was made and box is turned on, then something should show up on channel 3. If rca composite connection was made something should show up on video 1 or 2. Make sure box's power button is pushed to 'ON'.
Mar 24, 2009 | Insignia Digital-to-Analog Converter for...
They don't make a coaxial to RGB or Component adapter. I know they make a coaxial to RCA. If you go that route you would just connect the coaxial to the video. Now if you do this not sure as to what would happen with sound, if you would have it or not. It is possible but not sure. The adapter I am talking about is called a
UHF Female to RCA Male Coaxial Adapter. Which can be found at most Radio Shacks. If this doesn't work I would contact the cable company about a cable box that they could then run the coaxial to and then the RGB or Component cables to the TV.
Hope this helps.
Mar 01, 2009 | PC Connection RG6 Bulk Coax Cable, Plenum...
Trying to hookup and play standard DVD player
Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
Dec 12, 2008 | RCA F25441 25" TV
Hooking up a convertor , when i have a vcr, dvd player
You can hook it up through the antennae system. Keep your dvr connected to the tv the way you had it. Hook up your TV rabbit ears antennae to the converter box in the connection on the left side of the box. Then hook up the antennae lead from the converter box to your TV on the right side connector. The only thing I'm wondering is, do you get stereo sound this way and does anyone know how to get it without hooking up the separate audio and video plugs? There aren't enough connections on the tv to hook up both sets.
Nov 12, 2008 | Zenith C27A24T 27" TV
Problem with my ltv-19w6 flat screen TV
hi your tv will  not show picture if there is no cable or antenal connected insted it will show u the blue back baground
Sep 29, 2008 | Westinghouse LTV-19w6 Television
Lost color on Samsung TX-R2735
You may have a loose solder connection on a PC board in the color circuits. You might try jarring the set by hitting it at different places on the cabinet. NOT TOO HARD ! Like not with a hammar. If there is a loose connection it may show up. Also check to make the color level control hasn't gotten turned down. Hope this helps. Sometimes when you move a set you flex the circuit boards. If there is a poor connection it may show up--- in your case in the color circuits. Stargazer
Aug 11, 2007 | Samsung TX-R2735 27" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
