Question about RTO Groen Adi Foodservice Pressure Gauge
I must delime my groen hyper steam unit with port. What natural solution could i use? vinager?
    Brigadier General:
  • 4,090 Answers
Go to hardware and find a solution called CLR it removes calcium lime and rust. It is non poisonus so can be used on eating utensils. Vinegar is an acid and may damage stainless steel and other metals .
Please rate my help++++ Thanks for using FIXYA
Posted on Nov 17, 2009
Testimonial: "excellent fast response"
My water heater shuts down in cold weather. How do I fix this problem
Add tempering tank.
Tempering tank made from old tank-type water heater, or small tank heater will passively heat incoming water.
http://waterheatertimer.org/Tempering-tank.html
This works because tankless can only raise temperature so many degrees. If water is very cold, tankless cannot keep up, so the sensors shut down the unit.
Passively preheating water... or using a small tank connected to power can preheat water enough so tankless works.
Also delime tankless each year will help remove natural scale that builds up inside tankless heat exchanger.
http://waterheatertimer.org/How-to-delime-tankless-water-heater.html
Gene
Water Heater Timers Save Money
Feb 13, 2015 | Water Water Heaters
Groen SmartSteam
It may just be condensation on the coils, check to see if there is a drip pan on the unit, and if the drain is clogged
Apr 24, 2013 | Kitchen Ranges
My control unit keeps alternating between 120 and IL. Cannot find code IL
Before calling service technican, copy following links for general troubleshoot resources and error codes, and manusls, and Rheem contact information:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Rheem-CondensingTankless-maintenance-2012.pdf
Error IL usually means delime the unit.
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
Read your product manual for yearly/monthly maintenance schedule.
Tankless are maintenance heavy and must be delimed each year.
Deliming using white vinegar take about 1 hour, and will not restore full efficiency to unit.
Tankless have the habit of forming lime deposits inside the heat exchanger, even with softened water.
Tankless cannot be exposed to more than 11 grains hardness in water.
Don't buy a tankless next time.
Read the manual first.
Aug 09, 2012 | Rheem Rtg53xn Natural Gas Tankless Water...
My steamer on my Breville Die Cast Expresso machine no longer works, I have cleaned it, soaked it in vinegar. Any ideas?
Pleas do not soak this in vinager, try this process with vinager and most cost efficient way to fix this issue with HEAD SPRAYER HOLE clogging is to run vinager through the system several times. The compounds in the vinager serve as a cleaning agent to clean the heads naturally and allow the coffee to travel once again in the same holes it did when you first purchased the unit!!! Just fill up the pop with straight vinager and allow it to run through the system just as if it was coffee! This WILL NOT have any harmful affects to you or the coffee system unless you are allergic to vinager.
Jan 21, 2011 | Breville Die Cast 800ESXL Espresso Machine
I have a Keurig B60 coffeemaker. When making a
Descale yes you should every 3 months. Use 48 oz. of white destilled vinager and follow the instructions in your use and care guide
Mar 14, 2010 | Keurig B60 Coffee Maker
How do i delime a groen hypersteam hy3e this model does not have the port on the top of steamer
If this can stand to be immersed,soak it in a solution of CLR calcium,lime,and rust remover according to instructions on the label this should work. chibasset
Nov 14, 2009 | RTO Groen Adi Foodservice Pressure Gauge
Hatco Model c-21: How do you delime unit?
is there a way to disconnect the supply and run vinager thru the out let backwards to the supply with a hose attachment,,
Jun 23, 2009 | Water Heaters
Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Nov 15, 2007 | Irons
RTO Groen Adi Foodservice Pressure Gauge Logo
216 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Vuk B
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
