Recommended Frying Temperatures The actual temperatures and times used for frying will depend on the type of equipment used, the throughput and oil recovery rate, the size of the pieces being fried, the nature and condition of the frying fat or oil and upon local taste. However, the following temperatures and times are offered as a guide. Frozen foods may take up to a minute longer than the times indicated. Items Suggested Temperatures Approximate Time °C °F (minutes) Potato Chips, straight through 188 370 4-5 Potato Chips, blanching 166 330 4-6 Potato Chips, Browning 191 375 2-3 Potato Chips, frozen, blanched 180 355 4-5 Fish (battered pieces) 188 370 3-5 Prawns and Scampi (battered) 177 350 3-5 Meat cutlets 177 350 3-6 Chicken Pieces 171 340 6-12 Sausages 177 350 1-2 Fruit Fritters 177 350 2-4 Vegetables 177 350 2-4 Onion Rings 177 350 2-4 Doughnuts 188 370 1-2 Choux paste 182 360 1-2
If the fan is failing the most times the computer will not start because it will overheat. There are two fans inside the system, one inside the Power Supply and one that sits on the motherboard.
Remove the Power Cord, Open the case, Remove the cover and with a can of compressed air blow out the dust inside the computer. Clean the dust away from the Fans, Vents, CPU and Heat Sink are that sits under the Fan on the motherboard.
Use MODE button to scroll to ALM (alarm) then press INFO button to change from ON to OFF. If that doesn't work use MODE button to scroll to PACE, then press INFO button to toggle from ON to OFF.
When you change the ring on your Motorola V360 from the standard ring to another of your choice, you give the phone a personal touch. Rings, or ringtones, are included with your phone. You can also download and install ringtones from a mobile content provider or your mobile service provider. The ring you select sounds anytime you receive an incoming call. You can change the ring at anytime through the Motorola V360's settings menu.
Instructions
1.Press the "Menu" key on your Motorola V360 and click "Settings."
2.Click "Ring Styles" and select "Style Detail."
3.Highlight "Calls" and press the "Change" soft key.
4.Highlight the ring you want to use on your Motorola V360. When highlighted, a brief preview of the ringtone will play.
5.Press the "Select" soft key to choose the ringtone.
6.Press the "Back" key to set the ringtone on the Motorola V360
Read more: How to Change the Ring on a Motorola V360 ' eHow.com http://www.ehow.com/how_8468915_change-ring-motorola-v360.html#ixzz1XEda3gRH
---a score of 4 is highly appreciated-----
---if you think this resolution is helpful kindly click on "YES"----
---you may also leave testimonial-----
Thank you for choosing fixya
Roger
motorola do not yet support the w370 w375 with the latest version of motorola Phone tools
There is a 370 usb driver for download that also drives the w375, but it only allows explorer access to the images and sounds folders, not to addresses, or to use the device as a mode or any of the expected functions.
there is not supposed to be any driver required for winxp winVista, macs not supported
Note: The handsfree speaker won’t work when your phone is connected to a handsfree car kit or headset. this is all they have to offer http://motorola-global-eng.custhelp.com/cgi-bin/motorola_global_eng.cfg/php/enduser/std_adp.php?p_faqid=3056&p_created=1176240143&p_sid=yvNEkhXi&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjUzJnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yaW5nIHdpdGggaGVhZHNldA**&p_li=&p_topview=1 and vibrate and ring setting may be all you can do http://motorola-global-eng.custhelp.com/cgi-bin/motorola_global_eng.cfg/php/enduser/std_adp.php?p_faqid=1038
