Question about Garden
Poulan model 2150 auto oiler does'nt work? - Garden
4 Suggested Answers
  • 48 Answers
SOURCE: Auto oiler
The oil filter needs to be blown out, as well as the bar and behind the bar as the feed is just an open canal on the saw side of the bar. On your model their may be a guard that needs to be removed to access where the pump assembly comes out.
Posted on Apr 22, 2010
Testimonial: "I assume the oil pump is located behind the sprocket. Having trouble getting sprocket loose probably need a special tool.... Took the plastic 90 out."
  • 252 Answers
SOURCE: manual for Poulan chainsaw Model
yes
check out this site
http://www.hammerwall.com/Manuals/Poulan/Description/2150/Poulan%20Chain%20Saw%20Manual/L0403160/
cheers pauly46
Posted on Sep 13, 2010
SOURCE: Trouble with Poulan 2150 Chain saw automatic chain oiler
the tube to the the oiler metering valve is probably broke open. This happens with age. Replace the tube by cutting tube on sharp angle and push through the oiling port. using needle nose pliers pull tube in enough to cut and attach to the metering valve.
Posted on Jan 30, 2013
How do i replace fuel filter on a 2150 poulan
Pull the full filter out using a wire or tool that has a hook on it. Replace and drop back in.
Aug 30, 2014 | Poulan Garden
Poulan 2150, chain oiler not working. Chain is getting very hot.
Try to pour some gasoline only in the oiled tank and look if the gas comes out, if not the tank is clogged .
Oct 12, 2010 | Poulan 18" Chain Saw Replbar (small Saws)
How do you re assembly brake handle poulan 2150
Hello Larsens;
A Poulan "2150 Predator Gas Type 6" IPL follows (may not be your saw)(the LE suffix is a Wood Shark) http://www.ordertree.com/modelinfo/PWE/2150-Predator-Gas-Saw-Type-6/75.2150-Predator-Gas-Saw-Type-6.1.59.1.html
There is no breakdown, they want you to order a new cover $20±. The cover appears on different print names with different models (Handle & External Assembly) above.
Poulan.com (all)
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Do you have a friend with a cover you can look at? The brake will need to be lached open (enlarged) to refit the clutch cover on your saw.
Detail A here is a good representation of a Husky chain brake, they are all similar and this may be helpful.
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601077.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 24, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Auto oiler
Apr 22, 2010 | Garden
I need remove the clutch on my 2150 poulan pro chain saw, so I can fix the chain oiler.
Good film. Make certain the piston is above the exhaust port or the rope can fall through and damage the piston above the piston ring. When started it comes apart and destroys the saw.
The oiler worm gear is behind the metal cover visible once all clutch parts are removed. HTH
Lou
Jan 02, 2010 | Garden
Wood shark 2150 not oiling
Your model is a 2150LE. There is a Type 1 and 2. The linked IPL is a 2150LE Gas Saw Type 1. Click the "View the illustrated parts list [Go] button here:
http://www.ordertree.com/modelinfo/PWE/2150LE-Gas-Saw-Type-1/75.2150LE-Gas-Saw-Type-1.1.59.1.html
What little detail there is is on the "Handle, Chassis, & Bar" drawing.
A blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. The oil pump (52) is often behind the clutch. The saw can be operated without the bar and chain to verify oiler operation. GL
Lou
Sep 17, 2009 | Garden
Poulan oiler don't work
Common problem with Poulan and Craftsman gas saws. Take off the chain and chain guide and clean out all the saw dust etc. Start saw without chain and look for port where there are signs of oil. If port is clear of sawdust, then it is likely the pump which is located behind the chain break assembly. you can get the diagram on Poulan website and the replacement pump will cost about $15 - $20 to replace yours.
May 22, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need a diagram of the fuel lines on a poulan 2150. what lines go where?
You can View a Diagram of the Chainsaw here http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP⟨=EN&TF=Mainfram...
Select the Catalog Poulan/Weed Eater. Then Select Poulan. Then Select Gas. Then Select Saw. Then Scroll Down to your Model Saw i.e 2150.
Regards
Marc
Apr 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Hi
It is gear driven oiler and there is not any adjusment for it.
regards savumihai71
Dec 11, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
