Question about Toshiba 62HMX95 62" HDTV
Humming Noise at the back of my Toshiba 62 dlp lamp is working but no picture
    President:
  • 1,284 Answers
You probably should have the TV looked at by a technician. if your lamp is lighting up then most likely the noise is the color wheel itself.
Posted on Nov 17, 2009
Toshiba 62hm95 makes whirring noise and color is distorted
Your color wheel is going out and needs to be replaced. Toshiba does not list a part# for the color wheel. They expect you to have the whole light engine rebuilt. You should be able to find one on ebay. Or other sites like that. Good luck to you.
Apr 13, 2016 | Toshiba 62HM95 62" DLP HDTV
I have a 62" DLP
Replace the lamp, model # is TB25-LMP. Good luck
Jul 24, 2011 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 62" DLP Cinema Series
Could be the cooling fan. Is it under warranty?
-Kevin
Jan 04, 2011 | Toshiba 62HMX95 62" HDTV
62HM 95 TOSHIBA. HAD THE PICTURE JUST GO BLACK THE OTHER NIGHT. I HAD A LAMP FOR IT GIVEN TO ME BY A BUDDY IT MAY BE A USED ONE NOT SURE. REPLACED BULB TV CAME BACK ON BUT PICTURE IS TO DIM TO WATCH. DONT...
These Toshiba DLP's were lemons.
There was a class action lawsuit in the US and Toshiba were forced to issue a recall on the lamps. Toshiba replaced the first lamp for free but when the lamps are burning out every 6 months at a replacement cost of $200 these tv's are expensive to run.
Sounds to me like the light engine has failed. This will probably be a $800-$1000 repair.
Scrap it and take the hit.
Nov 01, 2010 | Toshiba 62HM95 62" DLP HDTV
Toshiba model number 62HM95 62' makes grinding noise
SORRY, This is from the authorized Toshiba parts center:
"The color wheel, lamp fan, lamp fan holder are parts of the LIGHT ENGINE only." It means the wheel is not sold separately and there is not even listed in the breakdown for the set a part number.
A replacement light engine (optical light engine) retails for 456.00 list and is sold on an exchange basis only.
SD TECH
May 13, 2010 | Toshiba 62HM95 62" HDTV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Hello, I Have a Mitsubishi WD-62725 (62") DLP rear projection TV. Ever since I changed the lamp the last time, the picture is jumpy when I turn it on, with all kinds of imperfections. It slowly goes away,...
This is a problem with bad capacitors on your FMT board inside the tv.. Not exactly a "do it yourself" type of repair unless you are very good with soldering and have electrical repair knowledge.
Jan 17, 2009 | Toshiba 50H72 50" Rear Projection...
No pic...humming noice on 62'' toshiba dlp
was the lamp blown if it was blown you could be hearing the ballast
if the lamp was not blown and the new one did not fix it the red light indicates the door there is a little switch when you put the door back on if you look at it it may need to be adjusted so it will connect with the door if that is not it you could have a fan that is not turn if it is making a real loud constant humming noise while it trying to fire the lamp you probably have a bad color wheel
Nov 19, 2008 | Toshiba 62HM95 62" HDTV
Humming noise & color changes picture flashes from red to green
our 62hm15 had the same problem and it was the dmd fan, which means the whole light engine needs replacing. this was going to cost us $1600. I hope yours is under warranty
Aug 09, 2008 | Toshiba 62HM95 62" HDTV
Toshiba 62HMX95 62" HDTV Logo
311 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
