Question about Kitchen Ranges
Spin cycle for tub broken - no spin, sounds like gears stripped.
Spin cycle broken, sounds like gears stripped, just sits there with that noise. I got it to drain the tub, pump appears to be working. Washed heavy load last night -an area rug, probably too heavy for the unit. Is it an easy repair or throw away? Took the agitator off, noise is still there, not the agitator. Must be the tub spinning mechanism? I've never been down there before. How do I get to it, need to take the back off? Is this a, ''fix it yourself'', a ''call tjhe repair man''- or throw it away time?? Thanks for your help, Ed
  • 77 Answers
Hi Ed can you please give model # and make so we can give better advice thanks.
Posted on Nov 17, 2009
When the machine starts to spin, a loud thumping noise starts.It sounds like it's hitting against the tub from underneath.The tub isn't off balance.we looked under it, didn't see anything broken.
check counter weights and suspension springs or rods then look for LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, DRIVE BLOCK, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket.
In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Another noise issue can arise from a worn SNUBBER RING on some washers that have a snubber like some Maytags, if u notice tiny pc's of white/grey shavings on the floor or around the bottom washer area? A sign of bad snubber. When removing to replace be careful as the spring underneath is pressure loaded.
A very similiar sound can be produced when the belt is worn but the difference is that a snubber noise can be produced during the spin cycle or when the cycle has finished and the spin tub is coasting to a stop. A worn belt noise can only be produced while the motor is actively engaged in spinning the spin tub. If it is discovered that the belt is worn and the base has black, shredded belt residue then it may not necessary to clean it out (belt residue generally will not cause a problem with the snubber). It will be necessary however, to find the cause of the belt failure.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
GRINDING NOISES:
The plastic drive is known as a splutch (splined clutch). One problem with these washers has been loosening of the nut that locks the pulley to the agitator input shaft. If it gets loose, the pulley drops and the teeth no longer have good contact with the teeth of the splutch basket drive gear in spin mode. The solution is application of blue locktite to the threads of the input shaft. There have also been a lot of failures of the actuator that operates the cam ring of the splutch which raises and lowers the basket drive gear. It is raised for agitate mode and lowered for spin. There is a spring between the basket drive gear and the gearcase housing that maintains pressure on the basket drive gear. There are cams on the cam ring that ride up and down on cams in the splutch cam (housing) as it is rotated by the actuator thus raising and lowering the basket drive gear. The gearcase has a planetary gear set in it.
One Way To Test For Spin Bearing Noise Is To Lift Up Top Part Of Machine With The Lid Taped Down, Explained Below, Put It In Spin Cycle, AndQuicklyPlace The Palms Of Your Hand Inside Of Basket Pushing Against Opposite Ends In The Basket To Stop It From Turning, Yes It Can Be Done Because It Takes A While Before It Starts Spinning At Full Speed, If Noise Has Gone Away, Its Your Spinner Bearing. Do Not Repeat Until You Stopped The Machine And Start Over Again. The Same Kind Of Noise Can Also Be A Bad Water Pump, Which Are Known To Fail And Have Since Been Redesigned, But That Noise Will Be Heard In Spin And Agitate Mode, And The Noise Will Have A Higher Pitch Sound, More Like A Screeching Sound.
Apr 13, 2017 | Washing Machines
Loud thumping during spin cycle maybe even a kind of screeching?
GRINDING NOISES:
Apr 09, 2017 | Washing Machines
Hello....Beko WM1 71641 The spin is noisy. When washing machine is off/empty, the drum is sluggish to turn. Wash cycle/spin seem to be working correctly. Thank you for giving this your attention
GRINDING NOISES:
Mar 18, 2017 | Beko Washing Machines
How do I fix the last few seconds of spin that vibrates off balanced and aloud noise.
Sep 23, 2014 | Samsung WF419AAW 4.3 cu. ft. Front Load...
Kenmore 400 make loud banging noise at end of the spin cycle
It sounds like the drive block may be stripped out. To check it, you will need to remove the agitator to see if it is bad. Below is a video to show you how to access the drive block. Here is the part to order if you should find it bad.
If the drive block is good, post back to me and we will continue the diagnostics on the unit.
Regards,
Richard Roth
http://appliancecafe.com
Nov 15, 2012 | Washing Machines
Make a really loud noise during the spin cycle
I would check the wash tub. Remove any clothes and examine how the tub sits in the opening. If it is sagging it could mean that the support arms are broken.
Try turning it by hand. It should turn smoothly without any noise. When the washer is in the spin cycle does it sound like a jet engine? If it does, it probally needs new bearings. It can be expensive to fix. Get a few estimates. Hope this helps you.
Jan 07, 2011 | Samsung WF218AN Front Load Washer
My Whirlpool Gold Ultimate Care washer doesnt agitate or spin. Makes a strange almost clicking like noise instead.
sounds like the drive block under the tub is stripped out or broken and it needs replacing,it sits under the tub to help drive the tub on direct drive models
Jul 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine broken, kenmore model 110.92274100
REPLACE THE DIRECT DRIVE COUPLING IT IS BETWEEN THE TRANSMISSION AND THE MOTOR PART NUMBER IS 285753A THE TRANSMISSION IS NOT BAD
Apr 22, 2008 | Washing Machines
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
