Question about Kenmore 24032\24036 Top Load Washer
Replacing belt on Amana LWD70AW top load washing machine
I have the new belt. I have an assembly drawing for the Pump housing assembly. How does the pump get removed so that belt can be placed around the motor's pulley.
  • k2scouter Jan 10, 2008
    I has able to fix it. thanks
  • Anonymous Apr 28, 2009
    i HAVE THE SAME PROBLEM WITH Model# LWD70AW, what's next after I receive a new belt?
  • 447 Answers
There is a post for this in my solved solutions. If you cant find
Posted on Jan 10, 2008
Hi. I am assuming you have the front cover off to be able to see the belt laying on the base. First thing is to make sue all bolts holding the motor assembly to inner frame are tight. Next, check your SPRINGS and their mounts...Rust and corrosion is main cause of failure. The belt goes around the water pump,transmission pully and inside of idler(tensioner) pully. Good luck! Dennis Wayne
May 13, 2014 | Washing Machines
Install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Apr 05, 2010 | Amana ALW895 Top Load Washer
Hello! The belt broke on our Amana Mod.# DLW330RAW . Could you explain how to install the new belt? Thanks Ron
Remove the bottom kick plate.
Remove 4 big bolts and unplug the motor. Move the motor assembly to a work bench. You need a T-20 torx driver to remove the pump screws and remember the rear pump leg goes between the belt. I have your Amana washer repair manual HERE
Mar 17, 2010 | Amana DLW330RA Top Load Washer
Broken belt . The belt broke on my ALW480DA Amana Washer. I can seem to be able to replace it becuase thre are four posts in the way holding the water pump housing. How can I change the belt.
you need to remove 3 or 4 bolts out of pump mount and slide pump down on shaft string belt and push pump back up and reinstall bolts in pump
Sep 26, 2009 | Amana ALW480DA Top Load Washer
Belt removal for Amana washer model#LWD70AW
u have to wiggle pump from side to side and up and down shoul losen up and pull strsight out
Apr 11, 2009 | Amana ALW480DA Top Load Washer
The belt broke on the washing machine
You will have to remove the whole motor assembly out, then remove the water pump using torx 20 from the whole motor
Dec 14, 2008 | Amana ALW480DA Top Load Washer
Replace belt on amana washing machine
Do you mean the water pump? If so, it's likely rusted on the shaft. I used a couple 15" screwdrivers as pry bars. Got it off, didn't break the pump, you might not be so lucky. Clean the shaft with scotchbrite, a dab of silicone lube will make it easier next time. If you have a camera take a couple pics BEFORE you take it all apart. The belt will fit 2 different ways, and one way will chew up the plastic pump support post. Don't ask how I know. (Took a lot of effort to get it off, but you have to in order to change the belt. A new pump, if needed, is about $20 around here.....)
Dec 06, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Belt Removal and Replacement
No.  The motor and pump assembly need to come off.
   There is 4 1/2 inch bolts that hold this assembly to the main mechanism.  2 on top and 2 on bottom.  Work belt off bottom pulley on transmission and then remove these bolts.  Turn motor over and remove 3 torx screws holding pump to motor.  Install new belt then reinstall pump with 3 screws.  Reinstall assemblt to mech.  Pu top 2 screws in first then bottom 2.  Be sure belt goes on left side of black plastic idler pulley.  Work belt around transmission pulley.  You can press on opposite end of idler pulley arm to loosen belt tension.  Make sure belt is on all pulleys before testing.
Oct 18, 2007 | Amana ALW480DA Top Load Washer
How to remove pulley from pump?
Your question suggests you are trying to remove the pump pulley. This pulley is not removable. The motor pulley should have a set allen screw in it to release.
Sep 26, 2007 | Amana ALW480DA Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
476 people viewed this question
Sal De
 Brian Main
Brian Main
