Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
I need to replace the vaacum belt and don't have a manual. Kenmore Canister
I need a manual for kenmore vacuum clearner #116 23812300
Posted on Jun 06, 2011
  • 701 Answers
Here is a link to the belt you need for your model and a link for the manual which shows you how to change the belt. Note that the manual doesn't say Kenmore but it is the exact same powerhead as yours:
Kenmore Progressive Replacement Belt
Instruction Manual
Posted on Nov 17, 2009
  • 3 Answers
You can find a manual online or at sears
Posted on Sep 29, 2012
How do I get to the belt on a Kenmore vacuum cleaner, belt on a kenmore elegance canister,
Take it to you local vac shop for service. If the belt is broken there is another problem. Those belts are not supposed to break. The machine has a circuit breaker. If the breaker didn't function properly and caused the belt to break, you will likely just break the new belt.
Feb 18, 2015 | Kenmore Vacuums
I cannot open and replace belt on Kenmore Model 116 (594299900) BELT ( 20-5285
The manual is here and there are diagrams on page 17 and 18 showing how to access and replace the belt.
http://www.hammerwall.com/Manuals/Kenmore/Description/116.20612003/Kenmore%20Canister%20Vacuum%20Cleaner%20Manual/L0705059/
I hope that helps
Jan 26, 2011 | Kenmore 25512/ 25513 Progressive Canister...
See were to put the swr driver on both sides and not sure where to pull up
I'm pretty sure you're asking about a Kenmore canister vacuum,
Here's what you'll need to replace a belt on a Kenmore2_bing.gif canister vacuum:
- Phillips Head Screw Driver
- Flat Head Screw Driver
There are two different types of belts2_bing.gif that are used on a Kenmore Canister. One of them is called a cogged belt, which has little teeth on the inside of the belt. The other is called a serpantine belt, which looks like a car belt, and has little grooves on the inside of the. You'll be able to tell which on yours takes after opening up the power nozzle.
This is the Cogged or Geared Belt with little teeth inside the belt:
Kenmore Canister Geared Belt for Canister Vacuums
This is the other Serpantine Belt that has little grooves on the inside of the belt:
Kenmore Canister Serpantine Belt for Canister Vacuums
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner2_bing.gif. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking.
Step 1. If you're power nozzle is a square shaped nozzle like the nozzle that I took a picture of above, then you'll need to first remove the headlight cover before you can access the roller brush and belt. Simply squeeze both sides of the headlight housing, and while squeezing, lift upwards with your fingers exactly where my fingers are located in this picture:
Step 2. After the headlight cover has been removed, you'll see two screws underneath of the headlight cover, directly in front of the neck of the power nozzle. You'll need to remove both of these screws. I have circled these screws in red:
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Here's a picture of the screwdriver prying off the right side:
Step 4. Now turn the power nozzle back over on top, and remove the top housing of the nozzle. You may have to push the handle release pedal in order to take the top housing off.
Thank you very much,
Chris J.
GoVacuum
Apr 07, 2010 | Vacuums
How do I replace the belt on my Kenmore canister vacuum?
Turn the power brush over so the bottom faces up. On the bottom there are two access screws. Remove the two screws and then the top cover can be removed from the base. With the top cover off you can access the belt. You can get a replacement belt for your model here:
Nov 17, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Progressive Kenmore hose canister connection broken 116,2341130
A regular person with patience can however it is tricky. Kenmore hoses have an arrow at the cuff where the corrugated hose meets the swivel elbow at the machine, and at the cuff where the handle meets the hose. If your parts fit in the handle, the cuff needs to be squeezed slightly out of round at the arrows to allow the handle to be popped out, usually by using a vice and applying a sharp blow by hand to the underside of the hand grip.
If your problem is in the lower sleeve area where dirt gets into the contacts at the machine end, there is a 1" clip with bayonets on either side. It must be compressed at the bayonets to allow the sleeve to slide off. The internal contact rings should be cleaned and polished with W/D sand paper #600 and then lubed with vaseline. Contact fingers should be spread to apply more pressure on the internal rings before reassembling in opposite order.
When in doubt Panasonic and Kenmore warranty centers will be familiar with these.
Aug 05, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Rollers not spining on my kenmore canister vac.
Particles of the failed belt may be  trapped in the bearings which, if I remember right, aren't very well protected.
I'd remove the rollers, slide the bearings off (if they do slide off) and blow them out with a compressor or saturate them with WD-40 and turn manually until they are free again.
Jan 15, 2009 | Kenmore 22313 Bagged Canister Vacuum
Need to replace belt
turn it over on the bottom by the roller there is a cover with 5 screws take off cover theres the belt........hope this helps
Dec 17, 2008 | Eureka 5848AV Bagless Upright Vacuum
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
1,598 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
