Question about Fasco Bradford White Hot Water Heater Exhaust Draft Inducer Blower # 239-42133-00
Armstrong sx 90 draft inducer is getting water in it.
Armstrong sx 90 ultra furnace draft inducer is filling up with water. I'm assuming the air is not getting pushed out of the ductwork quick enough causing more condensation to back fill. Is the draft inducer going bad?
  • 252 Answers
Nope, condensate drain clogged
Posted on Nov 17, 2009
    New Friend:
I have an SX90. After a couple of years in our home, I noticed a splashing sound coming from the inducer blower. Long story short, it wasn't draining properly and was causing a vacuum failure, so the furnace would shut down right after the main blower kicked on, then recycle. The installer had connected a drain tube to a port at the 9:00 position. Gravity rules. There was an unopened port at 6:00, so I drilled it out, hooked up my own tube and it has been fine ever since. I think the problem is that the flue pipe dribbles just a little bit when the furnace is off. Most goes into the drain, but enough finds its way into the blower to cause problems.
Posted on Jul 13, 2015
    New Friend:
I have the same problem. I flushed out all the condensate drains and they are clear. The blower is slowly filling with water and then eventually the pressure switch kicks out the furnace.
Posted on Jan 26, 2013
Model # 5vp40e-1 Richmond power vent hot water heater made some ticking noises very faint and stopped heating up.fan does not run either.
First try turning off the switch, unplugging it, replugging it in and flipping the switch to restart it. If this doesn't work, the first thing I would check is the draft inducer(looks like blowdryer) and the pressure switch which looks like a flying saucer. If you flip the switch, the first thing you should hear is the draft inducer blowing. If it blows and then stops, jump out the pressure switch and try to relight. If that works, it's the pressure switch.Replace it. There are other safety devices like roll-out switches and hi-limit switches that may be bad. Also, your flue pipe could be clogged, or your vent on the draft inducer may be clogged. Those will set of a safety switch because of overheating. That may be the ticking you were hearing.This is especially likely if your water heater is located in the laundry room because of all the lint floating around. If you've never troubleshot low voltage electric circuits before, you are better off hiring a service mechanic.
Feb 23, 2016 | Water Water Heaters
We have a Bosch AQ125BNG gas water heater. The pilot goes out in the middle of taking a shower and has to be relit. We have had this problem for a couple of years, but it only happens during winter months...
The problem is excessive down draft or condensation. Air flow is important in combustion appliances. Too much airflow down the chimney can blow the pilot out. This is readily apparent when it gets cold and there is air rushing down the chimney in the winter. There may be an air leak in the room with the water heater. While there should be a combustion air supply that is sufficient, there should not be a place for the air coming down the cold chimney to go. That would eliminate the draft. Another thing is if a furnace is in the same room and does not have enough air to supply the burners. IF it is an older furnace without a combustion exhaust fan or has its own flue, the air being drawn into the furnace burners may be blowing the pilot out. Last but not least is the condensation issue. When cold water enters the tank it can cause water to condensate on the outside and drip down into the burner and put the pilot out.
Jan 29, 2018 | Bosch AquaStar Indoor Natural Gas Tankless...
Hot water boiler wont heat up
If the draft inducer is bad then that will cause your system to go into lock down and will not work. You will need to check your vent pipe and everything all the way to make sure that there are no blocks or anything going on. If everything checks out ok, then you will need to replace the inducer motor and the system will work properly
Please rate
Jun 01, 2010 | Fasco GSW Hot Water Heater Exhaust Draft...
What causes soot build up in burner chamber
Sounds like you're not getting enough combustion air.
If you have a draft motor or blower make sure it is running.
Apr 30, 2010 | Fasco Bradford White Hot Water Heater...
No hot water. Gas co. serviceman says problem with draft inducer.
try to remove pipe you could have a clog water,ice,nest. also you may have a bad pressure swith hose find the hose and **** to see if it will fire
also if you take your pipe of you make turn on to see if you get fire you can not run for more then 30 sec with this off co. will fill the house.
Feb 13, 2010 | Fasco GSW Hot Water Heater Exhaust Draft...
Please help! Our draft inducer on our gas water
You are OKAY!!!
If the inducer connot run the gas valve will not turn on.
You will be fine till morning the way you are.
Just be sitting down when they tell you the price of a new inducer...
Heatman101
Jan 20, 2010 | Fasco GSW Hot Water Heater Exhaust Draft...
The elbow is broken and the air from the hot water tank is leaked
Any exhaust air coming from the gas water heater is potentionally life threating. I would get it fixed. Do you have a CO2 meter close by the water heater? If it is leaking air back into the house that has CO2, after a certain amount the alarm will go off. If you dont have one get one. A must have with gas appliances.
Jan 09, 2010 | Fasco Bradford White Hot Water Heater...
How does a draft inducer blower work
A draft inducer blower is used to create a proper draft in a chimney or exaust pipe from your water heater or furnace. In a high efficiency furnace or water heater, there is not enough heat expelled from the unit to the chimney to create a proper draft. The toxic carbon monoxide gas which is expelled through the chimney from your appliance is normally carried upward due to the rising hot air in the chimney. When appliances got more efficient (putting more heat into the water tank and less going out the chimney), manufacturers had to add this blower to help get the gases out the chimney since there wasn't enough hot air to create a draft.
Hope this helps.
Dec 10, 2009 | Fasco GSW Hot Water Heater Exhaust Draft...
Fasco Bradford White Hot Water Heater Exhaust Draft Inducer Blower # 239-42133-00 Logo
1,363 people viewed this question
Top Fasco Water Heaters Experts
Charles T Nevin
Charles T Nevin
vince
Are you a Fasco Water Heater Expert? Answer questions, earn points and help others
