Question about Technics SL-1200MK2 Turntable
60hz to 50 hz
Need to convert 60hz to 50hz ti testing equipment to sed overseas need to convert 230 60hz to 230 50hz
  • 515 Answers
No need to worry about that. The direct drive on these turntables will adjust for hz setting automatically.
Posted on Feb 24, 2008
What is the frequency of Briggs and Stratton portable generator 30552-00 and if it is 60 hz and I wanna change it into 50 hz, Is it possible and how?
It be better to obtain an unit that already design for your area as it will the appropriate electrical outlets.
As for the 30552-00 would be 60 Hz with running at a governed speed of 3600 (3750 unloaded).
Being a two pole generator frequency is determined by dividing engine as follows. 3600 / 60=60. Engine is RPM is in minutes and must converted to seconds. For 50Hz operation the engine speed must be reduce to 3000 rpm (50hz * 60seconds = 3000 rpm)
Feb 08, 2015 | Briggs Electrical Supplies
What is the wattage of Kenmore 385.15202 sewing
The wattge used should be listed on the machine or it's wiring. If not, you should go to ( sears.com ) and find support. I do not see a problem using an outlet there from a public power as long as you have set the unit to use the correct cycles which is normally 50Hz or 60Hz. Some electronic devices such as yours will operate on either, but you will normally have a switch to manually set which Hz setting you need. The power you recieve from the utility will be either 50Hz or 60 Hz and you will have to set the unit to match the utilities rating. Best Wishes.
Sep 01, 2014 | Sewing Machines
Losses Time
what frequency does Jordon use on their power is it 50 hz are the clocks 60 Hz designed power usage.
may need a device to convert 50hz to 60hz
search google for
50 hz to 60hz frequency converter
Apr 15, 2014 | Sanyo R-6800 2-IN-1 ALARM CLOCK AND RADIO...
Does not work on 50Hz kenmore elite dish washer
If it was built for 60Hz AC power (American), it will not work on 50Hz power. The Hz, is the number of cycles per second, the electricity makes. If your motor & controls are wired for 60cycles, they will not get the proper electrical supple to work on 50 cycles. AC voltage goes from neutral to positive to neutral to negative to neutral, (one cycle) according to the country you are in. Some countries also use 230 or 240 volts, instead of 120 volts.
Sep 10, 2009 | Dishwashers
Banding adjustment option in digital camera
50Hz and 60Hz is frequency of AC power supply. If you are in usa, select 60Hz and if in uk, select 50Hz to avoid flickers of florescent tube lights in picture.
Sep 08, 2008 | Canon PowerShot A75 Digital Camera
Will it work on 50hz?
best to call customer service 800-877-5032. if under a warranty would not want to lose it.
Aug 20, 2008 | Sanyo DP32746 32 in. LCD Television
Using battery charger overseas
it's alway suggested that you simply use plug adaptors to change shape of plugs for overseas-do not reduce voltage since most all chargers including yours support 220 or 110
Jun 07, 2008 | Cameras
I have magnavox TV
you will need an adapter for it....
its the current frequesncy what he told you.. in US they use current of 60hz frequecny....
the place you live in use 50hz.. that is the reason...
see this link...it wil help you surely..
50hz to 60hz - For: 1.Use overseas to test products destined for use in the US or other 60Hz countries;
2. To operate 60hz machinery from a 50hz utility.
Jan 19, 2008 | Philips Magnavox 51MP392H Rear Projection...
Different HZs problem (from 60Hz to 50Hz)
Yes there are frequency converters available but most are relatively over rated (industrial) for your requirement such as MDS Power or VisiComm Industries. What you need is a Low Power Solid State Frequency Converters lower than a
Electrocon Frequency Converters. However, I expect this devices to be rather expensive.
A few other options you may want to consider:
1. Contact the store where you bought if from; swap with an International version (Model SL-1210 Mark II; same price as SL-1200 Mark II); dual voltage switchable on rear of unit: 120 volts/60 Hz (U.S.) or 220 volts/50 Hz (Europe). You hopefully just spend for the cost of shipping + a restocking fee;
2. Contact 3rd party Technics TT specialist like TopDJGear, Quality Electronics, Planet DJ or DJHardware
and inquire if they would supply you the part(s) that you need to convert the 1200 to a 1210; or
3. Offer a swap on eBay.
Hope this be of some idea/help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 13, 2007 | Technics SL-1200MK2 Turntable
50Hz to 60Hz conversion
Hi, Your idea is basically sound and should work as long as the UPS originally is designed to produce 240V 60Hz and has its own built in timebase. The reason is that the input as long as the voltage matches makes no difference (50 or 60 Hz). By design, the UPS converts the input voltage to DC to charge the internal battery. The battery then powers an electronic circuitry that produces the 240V 60Hz. The input is then isolated from the output in terms of frequency. This is a common design, however, there are some (not many) that uses for its local oscillation sampling from the source and therefore will replicate the input frequency to its output, but very rare; it's better that you know they exist. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards. P.S. The only problem with 50 and 60 Hz is heat buildup which is tolerable and still within safe parameters. The only time the 50/60 HZ makes a big difference is when motors are used, timers such as in the early designs of microwave ovens, washing machines, etc., pumps and other highly inductive consumers. Most electronic devices converts the AC input to DC and therefore the frequency has negligible effect. Of course others may see it differently.
Sep 15, 2007 | Liebert UPStation GXT2700RT-208...
Technics SL-1200MK2 Turntable Logo
210 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
