Question about Refrigerators
We have an Amana side by side. The freezer door
We have an Amana side by side. The freezer door pops open about 1/4", it will not stay tightly closed. There are no obstructions. The closure is magnetic. It is an older model, we cannot find a model number on it and do not have paperwork. Probably bought it at Sears in the 1990's.
  • 10,865 Answers
Hi. First of all, finding the model number can be a bit of a challenge. here are the places to look:
  • Inside the refrigerator or freezer, on the upper left or right side wall
  • Behind the lower crisper drawer
  • Behind the lower toe kick-plate
  • On the face frame of the refrigerator body
  • Posted on Nov 17, 2009
    When I close my side x side frig the freezer door pops open
    This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
    Oct 17, 2012 | Kenmore Side by Side Refrigerator
    GE Profile freezer door problem
    I wil let you know of things you can do to solve this.
    Hope this helps, Thanks Sea Breeze
    Sep 22, 2009 | Refrigerators
    Freezer door opens when you shut the refrigerator door
    Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
    Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
    An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
    Sep 03, 2009 | Amana Refrigerators
    Frigidaire FRT17G4BW9 doors not staying closed
    Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
    Freezer door pops open when fridge door is closed.
    well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
    May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
    How do you level the kitechenaid side by side
    Hope this helps solve your problem, Let me know. Thanks, Sea Breeze
    Feb 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
    Freezer door wont seal and stay closed
    Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
    Hope this helped.Let me know by rating me or
    for more help go to live chat.Thanks
    Len West
    Feb 25, 2009 | Amana ARSE66MB Side by Side Refrigerator
    Freezer door won't stay shut
    This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
    Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
    Jan 18, 2009 | Refrigerators
    Amana 22 side-by-side refrigerator, freezer door opens slightly
    There are three possibilities to this problem:
    1. Door seal which should be magnetic is faulty.
    2. Ice maker caddy (container) has not socketed properly into ice maker rear drive tang.
    3. Door stay closed plastic hing pieces are damaged. These are tapered pieces that fit in hinge area that allow door weight to help close and hold door. Some are black in color and some are white. As far as I know they are interchangeable.
    Jul 17, 2008 | Amana 22.6 cu. ft. Side-By-Side...
    LG bottom freezer
    Sounds like the refrigerator is sitting lopsided.  Make sure that the front legs are both retracted in the up position.  If it doesn't work, then lower the front leg on the hinge side of the refrigerator.  That will cause the frame to lift the door and it should be able to close properly.
    Oct 25, 2007 | LG LRDN20720 Bottom Freezer Refrigerator
    Refrigerators Logo
    120 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
