Question about RCA PRO854 8mm Analog Camcorder
Rca pro854 I have a rca pro854 & can not gat it to work on my tv. It works on my daughters kareokee machine, but is small & in B&W. Could you tell which plugs go whre. I to have cable & a DVD player hooked up to my tv & my tv does not have the plugs in the front I would have to go through my DVD player. Hepl!!! Thanks
  • Anonymous Mar 30, 2014
    Sony CD/DVD player and Comcast cable Tv. Can't change the input on TV to watch DVD.
    Sergeant:
    Champion:
  • 317 Answers
You just need to match up the colors of the cables on both the camera and the DVD Player. Also, make sure that you plug the cables into an input on the DVD Player, and that The DVD player is tuned to that input usually accesed before channel 3 or by pressing input on the remote
Posted on Jan 10, 2008
52" RCA Scenum froze and would not turn off. I unplugged it and then plugged it back in. All the lights are on in the front of the tv but it will not turn on.
The small signal board is the most likliest cause of that issue which is a very famous symptom for the ITC222 and ITC222A chassis RCA models. You can usually get the small signal board from www.tvrepairworld.com several versions were used so they can assist with identifying which version ssb your model requires.
Apr 03, 2013 | RCA D52W19 52" Rear Projection Television
Hi I have a Mitsubishi ws-65615 65'' tv. I gat the green flashing light. I chainged the 4 capacitors, disconnect the front panel but still not want to work, still have the green light. ???????????????...
On the DM module where you replaced the capacitors there are three small white pico fuses. They are on the opposite site of the board. I would jumper all three by crimping a small piece of copper around them. Put the module back in place without its metal box around it. Plug the tv in and wait about two minutes. If the flashing light is off, turn it on. If this works, remove one of the jumpers. Continue until you have found the faulty fuse. Either replace or jumper the fuse permanently. When you put the DM module back in permanently, if the tv once again gives you the flashing light for more than two minutes, then the DM module is simply not setting properly into all of the pin locations.
Jan 05, 2010 | Televison & Video
Need AV input board for RCA E13320
The set shuts off after working for few minutes and can be turned on again some times after few minutes or few hours any sugestions please
Thank you
May 18, 2009 | RCA E13320 13" TV
Problems getting a RCA universal remote to work for Prima tv/dvd
after you press the code search button you have to press the dvd button then enter the code
is the remote the rca systrem link?
Feb 01, 2009 | RCA 20F510TD 20 in. TV/DVD Combo
Rca tv cant change password
use the default password of 0000 to bypass the unknown password....this is in the user guide for your model at rca
Aug 03, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
RCA D52W17 won't stay on.
Possiblility include bad convergence cuircit. A component that is overheating and bad solder connections.. Technicians can use special equipment to read error codes... this will tell them the error that is shutting it down
Mar 13, 2008 | RCA D52W19 52" Rear Projection Television
RCA 61" Model P61960 stopped working
You have a flyback transformer and horz output transistor bad
Nov 04, 2007 | RCA P61960 61" Rear Projection Television
RCA 32V524T won't power up. Chassis # ATC010T
I've had this TV for just over a year. Went to turn it on one day and it would not power up. I here a relay clicking. i suspect the horziontal drive transistor. Does any one have a service manual or know where I can gat one? first check power supply output if it ok than forget relay if not check power supply by dis connnecting horl. output. if it is ok check h/driver collector voltage if it is less than supply voltage than h/osc & driver ckt.is ok check h/output & its print for loose. regards thanks
Sep 10, 2007 | RCA 32V524T TV
RCA PRO854 camcorder
maybe I would buy your camera,
yes as far as I know hi8 and 8mm are completely different cameras,
where are you and how much for the camera?
david@fullbliss.com
Jan 21, 2007 | RCA PRO854 8mm Analog Camcorder
Video Cameras Logo
78 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
