Question about LaCie (300770) 250 GB Hard Drive
My lacie drive will shows up on the desktop and you can see all the folders and files but it will not allow me to open up my project files in Final Cut Pro.
    Scholar:
  • 55 Answers
I'm going to have to guess a bit based on limited information I have on this, but did you create a Final Cut Pro sequence on the Lacie on one computer and then are trying to open the sequence on another computer?
That won't work if that's the case ...
The FCP sequence refers to files, but doesn't include them in the sequence file ... All of the referred to files will have to go along on the Lacie and be transferred to the same folders on the second computer so the FCP sequence will find them.
You can try consolidating the project in FCP to make the transfer easier ... after consolidating it, the files needed for the project should be trimmed and all located in one place (scratch disc selected in preferences)
Once again, the sequence file does not contain your movie clips, audio or other assets .... they are located in different places on the computer where you create the sequence, and if you move to another computer everything has to move into exactly the same place ...
Hope this helps
For my latest DVD on PA systems for Small Groups see my website at www.whamuniversal.com
Posted on Mar 07, 2010
Lacie hard drive files say cannot be modified
this might be a read only file make sure you have full control
right click on the folder select Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this help you
Nov 22, 2011 | LaCie Rugged All-Terrain (301017) Hard...
Was using my 1TB and then all memory (pictures) dissapeared. Still shows memory used/available, just all the files are gone.
Those files are hidden folders.
For that connect it to computer then open my computer go to tools menu->folder option.
then click view tab enable "show hidden files and folders" and disable check box of "hide system files" then apply then you can see your files as hidden folder.
then open it then copy all files to local drive also scan computer and harddrive with updated antivirus because it (harddrive) is infected of virus.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 09, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I just cannot fiew my files I backed up. I do not see the ALacie in the device drivers
if ur drive is in NTFS format plz go to the drive right click on that drive go to properties go to security and tick on allow ,before tick allow u should untick all the deny coulmn
May 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
My Lacie driver is no longer acessable
you could send me it lol :)
When you say it gives you a blank window did you leave it for a while - I have to do that with my 500gb hard drive which has a lot of stuff on it and it takes a while to read what it needs to before it shows the files / folders
maybe a defrag if you can get it back up and running and also try it on a different usb port on the back of the same computer it was working on
May 16, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie USB 2.0 No files or folders displayed in backup folder
Did you try showing "hidden folders and files"?
In the Explorer, select the Tools menu, and pick Folder Options.
Select the View tab and in the list enable "show hidden files and folders".
You can also try showing system files (so choose not to hide them).
That should show you all files and folders on the disk.
Do make sure you are logged in as a user with admin rights.
May 13, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Backup folder shows as empty
Have you tried showing hidden and system files?
In the Windows Explorer, go to the Tools menu and select Options or Folder Options.
In the View tab, scroll in the list and make sure show hidden files is selected. You can also unselect the 'hide system files' option.
That will show you anything on the disk!
Jules
Apr 02, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
LACIE 500 GB HARD DRIVE
i use my external hard disk many times but now when i connect my lacie external H.D to PC it dose not recognized
Jan 30, 2009 | LaCie (300951U) 500 GB Hard Drive
Placed all working folders for a roxio videowave project on desktop. Photos, playlists, etc. If I move these to "My Documents Folder", the roxio slide show does not work. the program can not find...
i have not used the Roxio software but i am sure if you open the program then got to the function that allows you to open files ,
it will give you an option to search the drive to find where you have saved (or moved) these files to.then select where you have placed or saved them.
good luck & please rate my efforts
Terry
Apr 03, 2008 | Computers & Internet
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
Lacie drive won't mount
I solved the problem. It was a power supply problem. It seems after searching boards on the net, this is a common problem with the lacie hard drives. Just replace the power if your hard drive is clicking and not mounting. I think many people must be throwing the drives away thinking they are lost when it is just the power supply. Try this first before trashing it or spending a lot of money on data recovery programs/
Nov 13, 2007 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
LaCie (300770) 250 GB Hard Drive Logo
228 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
