Question about SanDisk ULTRA II 4GB Compact Flash Card Flash
SanDixk Ultra II 2GB
Well I was uploading pictures into my computer directly from the card to the computer.
But when I tried using it again on my camera it says "Card cannot be used"
Did I remove something accidently or what? How can I fix it... VERY URGENT!
  • 1 more comment
  • theLOTRfan Jan 10, 2008
    Haha. Im new at this...
    So how do we reformat a card?
    When I click on it to open it, it opens up some folders. But when I try to open those folders. It doesnt work.
    When I tried to reformat, it told me there was no disk. When there clearly was.
    Ouch. Thanks though...
    Sergeant:
    Champion:
  • 317 Answers
Check and see if there is a locking pin on the cartd, as this will sometimes cause a problem, also, try reformatting the card to FAT 32 or even NTFS
Posted on Jan 10, 2008
  • Alexander Selby
    Alexander Selby Jan 10, 2008
    go to my computer, right click the card and select "format" the rest is pretty self explanatory
  • Alexander Selby
    sounds like the disk is messed up, seems there is no other solution, other than to get a new one or find someone who can fix it. My Best Regards
My Scandisk Ultra 2GB shows pictures on laptop, yet not on camera...the pictures are on the card. I did download them on my computer, removed them from the card, zoomed, cropped etc on Windows, then...
It is possible that when you edited the pictures on your computer, that you might have changed the file format when you resaved them.
Check the names of your picture files on the computer and compares the endings (.JPG or .BMP or whatever) between new pictures that come directly from your camera and pictures that you have edited and resaved.
If the formats are different at all, then your camera will probably not be able to read them. Cameras usually save pictures in one specific format and can only read them if they are in exactly that format. A computer on the other hand is much more flexible and can usually read or save pictures in many different formats.
Your computer should give you the option of saving a picture file in a different format if you want. When you edit and save the pictures on your computer next time, use the SAVE AS feature, this should give you the option of changing the name of the file as well as the file extension from a drop down list. Then just try saving the picture files in different formats until you find the one that your camera can read. Or just look in your cameras Owner's Manual and find out exactly what format the pictures need to be in for the camera to recognize and display them from a memory card.
Good luck.
Apr 14, 2011 | SanDisk Ultra II 2GB Secure Digital Memory...
I have an Ultra II 4gb memory card that is locked and I can't seem to unlock it. I've tried from multiple cameras, card readers, and computers, but can't seem to get it to work.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 11, 2011 | SanDisk Ultra II 2GB Secure Digital Memory...
Formatting an CF 4GB sandisk ultra II....How to do
The camera uses FAT16 so it won't be able to use cards bigger than 2GB. IF you can format it, you will only have 2GB space available.
Formatting the card: Press Menu/OK, select Setup, Select Format, press OK untill it's done.
Oct 11, 2009 | Fuji FinePix S7000 Digital Camera
San Disk 2GB is saying it's full when it still has plenty of room
I didn't understand you weren't using it for photography. Here some more suggestions:
* Double check the SD card's Write Protection Switch to make sure it is unlocked.
* If your card reader is old it may need to be replaced. See if the card works properly in your camera. If you hook your camera to your MAC with its USB cable you should be able to upload and download files.
Sep 18, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
The computer would not upload a certain video from my camera.
If you have a memory card reader that can read the SanDisk Ultra II memory card, then you can use a data recovery software like Restoration to recover whatever was stored on the memory card.
Restoration is freeware & you can download it at the following link:
http://www.snapfiles.com/get/restoration.html
Although it is freeware, it is very good at doing the job. I used it several times & it never let me down.
Jul 13, 2009 | PNY 2GB microSD Memory Card
Memory card locked
On your SD card, there is a small tab near the top (similar to floppy a disks), just switch that the other way it should fix that lock error.
Jun 11, 2009 | SanDisk Ultra II 2GB Secure Digital Memory...
Cannot upload pictures from LG Shine phone to computer
If your pics are on your card for sure than you may half to remove the card and connect it directly to your computer. The file may have been
saved to the wrong part of the card. This may not be the answer but it
has happened to me in the past. If you have not saved the pics to the
card that is your problem. You must save the pics to the card and try again. You should be able to select a pic and move it to the card.
after you do either of these two ideas you should be able to move your
pics to your computer. hope this helps.
Apr 25, 2009 | LG Shine CU720 Cellular Phone
San disk ultra II won't show up on computer
You'll have to go to Sandisk.com to verify this for your specific model, but... the problem is that some firmware versions won't recognize over a 2GB card. There may be a firmware update available. Find your product on the site using search, and then look for software updates. Don't hesitate to call techsupport (866-726-3475).... usually NOT a long wait, they speak clearly and they're polite.
Feb 04, 2009 | SanDisk Ultra II 8GB Secure Digital High...
Card error
try to examine the card on a computer (e.g. with a card reader). are there any pictures on the card? if not, try formatting the card (see olympus manual for a how-to).
Dec 26, 2007 | Olympus EVOLT E-410 Digital Camera
SANDISK ULTRA II 2GB CF PROBLEM
Hm, odd problem, I'd try reformatting the drive (Windows) My computer > Right click > Format. If the drive's corrupted, that could be causing your problem. But remember, formatting will erase ALL data on the drive, back it up before you try this.
Aug 22, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk ULTRA II 4GB Compact Flash Card Flash Logo
115 people viewed this question
Top SanDisk Cameras Experts
Henry
Nikki  Mclean
Nikki Mclean
Are you a SanDisk Camera Expert? Answer questions, earn points and help others
