Question about Kenwood Excelon KVT815DVD Car DVD Player
Wiring i got the wires hooked up except for the orange wire with white stripe and the brown wire coming from the power from the hideaway unit that comes with the deck
  • bighoss Jan 10, 2008
    where does the orange wire with white stripe connect to and where do the brown wire go i have all other wires hooked up already
    New Friend:
HOW THA FUCC I HOOK UP MY FUCCING SCREEN RADIO
Posted on Oct 11, 2008
WHATS THE WIRED DIAGRAM FOR AN PIONEER AVH-4900DVD
    Problem Solver:
  • 15 Answers
The brown wire, according to the installation manual, is the "Mute Wire". Their instruction is:
"Connect to the terminal that is grounded when either the telephone rings or during conversation."
So this appears to only be necessary if you are also using a mobile phone with your system.
The orange/white wire is the "dimmer control" lead, which should be wired into the switch that turns your car lights on and off. This will probably allow your head unit to dim when you turn the car lights on (night time).
Hope this helps!
Posted on Jan 14, 2008
IM TRYING TO WIRE A PIONEER DEH-5 TO MY STOCK WIRES IN MY 1996 VOLKS JETTA. I CHECKED OUT THE WIRING DIAGRAM ON THE JETTA AND SOME OF THE WIRES DID NOT MATCH UP,LIKE FOR INSTANCE THE SWITCHED WIRE ON THE...
Hi, the plain orange wire is the power wire. The constant wire is only for maintaining the station presets--it does not power the unit on. The other orange wires are for speakers. See the full color code below, and let me know if you have any more questions.
1996 Volkswagen Jetta Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/White
Car Radio Switched 12v+ Wire: Orange
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Gray/Blue
Car Stereo Amplifier Location: If equipped, each speaker has an individual amplifier located at the speaker.
Left Front Speaker Positive Wire (+): Blue/Black
Left Front Speaker Negative Wire (-): Orange/Black
Right Front Speaker Positive Wire (+): Red/White
Right Front Speaker Negative Wire (-): Orange/White
Left Rear Speaker Positive Wire (+): Red/Light Green
Left Rear Speaker Negative Wire (-): Orange/Black
Right Rear Speaker Positive Wire (+): Blue/Light Green
Right Rear Speaker Negative Wire (-): Orange/Red
May 07, 2011 | Alpine CDM-7874 CD Player
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
(Gray Plug)
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
Cat 5 cabling
Straight Cabling :
Side 1 Side 2
White Orange White Orange
Orange Orange
White green White Green
Blue Blue
White Blue White Blue
Green Green
White Brown White Brown
Brown Brown
Cross Cabling :
Side 1 Side 2
White Orange White Green
Orange Green
White Green White Orange
Blue Blue
Green Orange
Brown Brown
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 11, 2010 | Computers & Internet
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
Bought brand new car audio head unit CQ-RX420W, but no installation instructions. Blue and brown wires, not sure which is for aerial and what the other is for. Can you help?
what you have there is a good panasonic head unit. the solid blue wire is going to be used for an automatic antenna.
Yellow- Constant Power (keeps memory for your clock and presets)
Red-Switched Power (turns your radio on when you turn the key)
Black-Ground
White- Left Front speaker (+)
White w/ black stripe - Left front speaker (-)
Gray - right front speaker (+)
Gray w/ black stripe - Right front speaker (-)
Green- Left Rear Speaker (+)
Green w/ Black stripe Left Rear speaker (-)
Purple - right rear speaker (+)
Purple w/ black stripe - right rear speaker (-)
Blue with white stripe - power out, (commonly used for the amplifier turn on wire, or antenna wire.
you may have orange wires in your harness,
or brown ones. these you dont really need
the orange wires are for your dash board dimming lights
and the brown one is for Tele, Muting.
what kind of car do you have, i can give you the wire harness colors
Dec 30, 2009 | Car Audio & Video
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
Need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
May 31, 2009 | 1995 Mercury Villager
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Kenwood Excelon KVT815DVD Car DVD Player Logo
304 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
