Question about American Standard Cadet 3 Right Height Elongated Toilet by - ADA Compliant
Fluids splash out when flushed
I get major "splash-back" when Cadet 3 is flushed. Must flush with lid closed otherwise fluids splash out. What adjustments can I make?
I went through this and called the help line. If the bowl is almost empty after flushing, it may be the water fill line in the fill tank (reservoir on the back of the toilet). There is a small tube that should go into the overflow tube and it adds water to the bowl after flushing. Mine was not attached to the overflow tube when I took it out of the box and the instructions did not mention to check it (or the troubleshooting guide). A picture is worth a thousand words so look for the small white hose going from the fill valve into the overflow tube:Fluids splash out when flushed - _1365.jpg
Posted on May 28, 2011
  • 119 Answers
Defective toilet contact American Standard for a free replacement or return to store if you purchased it there are no adjustments I had the same problem with Toto brand some years ago
Posted on Nov 23, 2009
The volume of water must be on the highest level in the cistern . so pop off the lid and have a look . if the water is up past the fill to mark you must adjust the inlet by first flushing the water to seethe inlet working so you know where the water is entering through the bottom of the inlet valve . thats what has to be adjusted the inlet valve is ether faulty or just set on the high tide mark where it can only handle the lower tide mark . adjusting the valve is eazy and you can do it with bare hands by a twist to the left and push down until it is at the lower level then twist it back to the right and test it . i dont turn the water off when i adjust inlets but you should , im a plumber
Posted on Nov 27, 2009
Should I have brake fluid flushed in my 2007 tiburon
not really needed unless you have had a major failure with either system...its a gimick alot of shops use to make quick money with uneeded repairs
Dec 03, 2012 | Hyundai Tiburon Cars & Trucks
Shifting at 3000 rpm 3 days after fluid and filter change
please do not tell me you had it flushed at a fast lube place,and they back flushed it. back flushing is ok with old transmission,but with the new transmission back flushing cuases the shift sensors in the transmission to close and not open
Nov 08, 2012 | 2002 Honda Passport
My Cadet 3 toilet worked fine for a year. A plumber fixed a leak at the intake line. Since he left the bowl does not fill with enough water. This causes water to splash when I flush. The flapper has a...
thumbnail.aspx?q=411971824072&id=9a63c0e833b7cdbd3aca7d8622bc1566&url=http%3a%2f%2fwww.askmehelpdesk.com%2fattachment.php%3fattachmentid%3d14345%26stc%3d1%26d%3d1228681261
This is diagram of a typical toilet tank setup if the refill tube is not putting water into the flush valve as pictured the toilet will do what you have described.
Feb 12, 2011 | American Standard 4112.016 Cadet Toilet...
Flush does not completly empty bowl. Must hold down handle for it to work. Tightened flush handle chain.
replace the flapper. this usually corrects the problem. make sure you get the right flapper for it, not a universal flapper, they don't work.
if you are unsure what model you have, remove the lid on the tank, and look for the model number stamped into the back of the tank.
Aug 17, 2010 | American Standard Cadet 3 Right Height...
After flushing, water level in bowl fills and then slowly drops.
Check to be sure small tube is flowing inside the ovefow tube. This is the water that flushes the rim holes, and refills the bowl. If you don't have flow clean or replace the float valve.
Jul 19, 2010 | American Standard Cadet 3 FloWise...
I just installed an american standard cadet 3.Home depot rated this toilet as a 10 for flush power. when I flush 1st off the flapper wont stay up on it own long enough to flush,2nd if I hold it open it is...
We have just recently purchased one of the American standard cadet at home depot from a discount flyer and had it for about a day and took it back.
Like you said, Did not notice Any thing like a strong flush.
RECOMENDATION:
Take it back.
Home Depot also sells a Kohler Toilet 1.6 Gallon Flush Install
This is all it said it was. It saves water for sure and has a quick flush.
We liked it so much we purchased two of them because everyone in the house only wanted to using our bathroom.
Hope this tip helps.
r/
David
Feb 24, 2010 | American Standard Cadet 3 Round Toilet...
Toilet flushing problem! I purchased an American Standard Cadet 3 High HET toilet (1.28 gallon). When I flush the toilet, the flap will not stay up to allow the water to drain from the tank. When handle is...
The siphon mechanism works on a vacuum principle. If there is the slightest damage to the siphon membrane you will experience the problem you describe. A new siphon is required.
Dec 31, 2009 | American Standard Cadet 3 Right Height...
After depressing the flush lever the flapper closes to quickly
The flapper is designed to close quickly. It holds more water in the tank then it uses to flush. That way it is ready to flush again quickly.
If it is not removing all the contents then there may be an issue with venting or blockage in the pipe.
Oct 18, 2009 | American Standard Cadet 3 FloWise...
Cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
May 08, 2009 | American Standard Cadet 3 Right Height...
American Standard Cadet 3 Right Height Elongated Toilet by  - ADA Compliant Logo
782 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
