Question about Welding Tools
Hey i have a PRO 165AMP AC ARC WELDING MACHINE WELDER. it turns on normal, but i'm not getting any spark. what could this be
  • 3,600 Answers
Try cleaning the ground ******** both ends and try cleaning the rod holder, if eather has burn marks on it it will not burn, let me know if this does not help. Most tims it's the ground connection.
Posted on Nov 25, 2009
I need tips for my stud welding gun. How can I replace them? Thanks John
https://studweldprod.com/
Stud Welder - Stud Welding Equipment, Gun - Stud Welders Machine
www.eastwood.com > Welding & Fab
  1. Cached
  2. Similar
Stud welding makes more sense. Our stud welder systems each have a stud gun welder that spot-welds a series of pins onto the surface of the dented metal.
What is Stud Welding? ' Sunbelt Stud Welding
www.sunbeltstudwelding.com/studwelding.htm
  1. Cached
  2. Similar
Weld studs come in a variety of designs, threaded, unthreaded, tapped, etc., ... The welding gun is activated and the fastener is welded in a fraction of a second.
Stud Welding Machines and Equipment ' Red-D-Arc Welderentals
www.red-d-arc.com/rental-equipment-subcategories.aspx?sub_cat=180
  1. Cached
  2. Similar
Red-D-Arc offers a range of fully regulated, user-friendly stud welders, stud welding machines and equipment available in single or dual gun versions and ...
Jan 30, 2017 | Welding Tools
What mig gun is on a Nevada 220BZ Mig Welder
Nevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder ...
www.ebay.com.au > Industrial > Welding > Welders
eBayNevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder Welding ... Nevada Welding machine; MIG Torch; Earth Clamp; Electrode Holder; Safety Mask ..
Dec 20, 2015 | Welding Tools
If I turn the ac dc switch while what dose it do to the wielder. Now im not getting any juice to wield .thank you
Changes between AC and DC voltage at the electrodes.
Q: What Type Of Stick Welder Works Best For All-Around Use?
A: A welder with an AC/DC output, whether its an electric arc machine like Miller\'s Thunderbolt or a gas engine drive like Miller\'s Bobcat.
DC welding offers advantages over AC for most Stick applications, including: easier starts; fewer arc outages and sticking; less spatter/better looking welds; easier vertical up and overhead welding; easier to learn "how to weld" and a smoother arc. DC reverse polarity (electrode positive) provides about 10 percent more penetration at a given amperage than AC, while DC straight polarity (electrode negative) welds thinner metals better.
Q: Does An AC Output Have Any Advantages?
A: Yes, if you need to weld on material that\'s become magnetized from friction, such as when hay, feed or water constantly rub against a steel part. A DC output won\'t work because of "arc blow," where the magnetic field blows the molten filler metal out of the weld puddle. Because an AC output alternates between polarities, it enables you to weld magnetized parts.
Aug 19, 2014 | Computers & Internet
Lincoln electric ac/dc arc welder will not arc
Check the dial indicator. Sometimes if someone changes the amps while welding, there will be a break in the coil. It will work at a different setting as long as you are away from the break.
Jul 17, 2014 | Lincoln Electric K1297 AC/DC 225/125 Stick...
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
My welder is not sparking strong enought to weld I raise the amp all the way and it is not sparking like it should what could be the problem
make sure there is nothing getting in the way of the current flowing through the ground. slow down and keep the arc close to your metal.
Jan 27, 2013 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
My tig welder wont arc unless I touch the metal with it
my guess would be the type of welding machine you have.usually there is extra switch which says start control also continious cycle , sometimes smaller machines dont have these switches to allow a wider variety of tweeking the welder ,also its ok if you have to touch the base metal cause thats what starts the contact with the work peice ,keep a arc after touching about 1/4 inch away from work peice ,also a good steady hand rest will make a good welder in any situation this should allow the arc to remaim stable with a comntinious weld arc puddle. happy welding
May 22, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
I have a miller microwave 200. what settings should i use for aluminum welding? dcep, ac, dcen? i'm using a3/32'' tungsten and trying to weld on 1/4'' alum plate. the weld is not turning out to be a smooth...
I think you mean you have a Miller Synchrowave 200.
Typically, you would want to use AC below about 250 amps. In this case (to keep it simple), use AC, adjust your balance to about 4, use an 1/8" pure tungsten, pure argon at about 20CFh, and set the panel at 170amps to get things started. For general purpose, use 4043 filler.
Now - these are just generic settings, but they will get you going.
Jan 12, 2010 | ARC Welding Secrets Book - Mig/tig/oxy/arc...
ARC 225 - Can't hear fan.
sounds like you lost one leg of power to the unit,check power source and the the plug on the welder.
Jul 30, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Welding Tools Logo
62 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
