Question about Frigidaire FWT449
I have a frigidaire front load washer model fwt449gf. What is the best way to get the door safety switch out? The front seal appears to be glued on so that route is not available.
You can carefully pry off the seal with a knife or similar tool, focusing on the glue points which on mine were at the 2, 4, 8 and 10 o'clock positions. I then installed a door lock switch kit which came with glue/cement to glue it back on once you are done, but you could probably use any good general purpose contact cement because the seal wants to stay put on its own.
Posted on Dec 02, 2009
  • 68 Answers
Mounting screws are behind door on front panel. Remove front lower cover and reach up to remove lock.
Posted on Nov 17, 2009
Remove door gasket
There is a spring that goes all the way around the door, just under the edge of the gasket. If you remove that spring starting at the bottom of the door, you should be able to remove the gasket for replacement
Mar 26, 2014 | Frigidaire ATF6000ES Front Load Washer
Water leaking out of door
as long there isnt an overload or water level sensor issue
you can replace the door seal
also check door catch /safety switch
Mar 08, 2014 | Frigidaire GLTF2940ES Front Load Washer
How do you replace the door switch on Frigidaire ltf2140es0 front load washer?
You will need to remove the wire ring on the door seal and carefully peal back the seal to reach your hand in to hold the door switch as you remove the 2 screws. Then pull it out and unplug wires one at a time and plug into the new one. This is a easy DIY and only takes about 15 minutes.Here is a link that should help Door switch replacement
Feb 05, 2011 | Frigidaire ATF6000ES Front Load Washer
My frigidaire washer will not spin, why
You will need to check the door switch you should have 1500 ohms no less than 1400. To check remove wire ring from door seal carefully peal rubber seal off flange. The remove 2 screws holding switch and carefully take out. Check with ohmeter. This is a fairly common problem with that model. For the lowest price on parts go to www.appliancehelponline.com
Mar 28, 2010 | Frigidaire GLTF2940ES Front Load Washer
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Broken electronic connector on washing machine
seawolrf your going to have to do a little work...open the door now looking at the washer i want you to take a knife or screw driver and take that gasket off right next to the door switch,,the black gasket is glued ,,yes glued pull it up..only by door switch..now remove door switch screws (2) now replace that connection...onthejob
Jan 27, 2009 | Frigidaire FTF530FS Front Load Washer
Front door buzzing Frigidaire front loading washer
replace entire door lock assembly ..remove spring holding the door boot in place and roll boot back ..unless you have the one where the seal is glued then carefully slide knife under edge to cut through glue take the screws from lock and pull through opening remove wires and install new lock ..if noise is only issue use till it blows then replace
Jul 30, 2008 | Frigidaire FWT449
Frigidaire Gallery Model FWT449GF Tub issue
level and balance is very important for all machines. make sure it is firmly seated on floor and shipping bolts pins and brackets are removed (some have brackets inside.) the machine should be able to evenly distribute the load. finally the shock absorbers could be bad. (seems rare on frigidaire)
Mar 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Front Load Door Lock Broken and Noisy FWT449GF
Its looks like a lid switch issue. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Good luck!
Sep 08, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
222 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
