Question about KitchenAid K45SS Classic Stand Mixer
Making grinding noise - KitchenAid K45SS Classic Stand Mixer
  • 55 Answers
Is it working? Probaly gear unit inside, we fix these at $29-$59 depending on which gear is broken
USPS ships very inexpensive
Posted on Nov 23, 2009
Grinding sounds
The case screws can come loose and grind on the planetary. To see if that's the problem you need to pop the chrome drip ring off that covers part of the planetary. It's just a push fit, pop off with screwdriver tapped with a hammer.
Feb 06, 2016 | KitchenAid Food Mixers
Mixer making a grinding noise when turned on
It sounds like it is the worm follower gear, it is the most common gear to wear out as it takes the most pressure but it could also be one of the three bearings that are in there also, or it could be the worm gear, you will just have to open it up to look for wear. there are several really good videos on you tube that will show you how. it really is an easy fix if you are a good handy person, hope that helps
Feb 13, 2013 | KitchenAid Professional Heavy Duty Series...
KA 600 is making a clinking noise when mixing.
Tll,
It sounds like it could be an issue with the gear, the motor housing could have a crack in it. The problem could be much more involved as well. Put the unit on the slowest speed and see if you can stop the mixer from spinning. If it hiccups or stutters, that means you have a stripped gear. If you cannot stop the unit using your hand ON THE SLOWEST speed then there could be a problem with the motor housing or the motor itself not being held in place properly.
Apr 02, 2012 | KitchenAid ProLine 600 Stand Mixer
The motor is making a grinding noise. The mixer still works, it just sounds weird.
I have fixed many mixers with the same problem. The only part that consistently wears out
is the Worm Gear Follower located inside the Transmission housing. The teeth are wearing out
and becoming chipped. The grinding noises you hear are made by the Worm Gear and the
Follower. As time goes on, the metal filings from the damaged follower will eventually destroy the Follower and the Planetary will stop rotating.
Sooner or later that gear need to be replaced. Also remember to use new Grease after
a new gear replacement (metal filings from the old gear will damage your new gear)
Apr 02, 2011 | KitchenAid KP2671 Professional 6 Series...
My 6qt Kitchenaid stand mixer started making a grinding noise and beater bar keeps stopping. When I put it gently with my finger, it begins turning, only to stop again and make that grinding noise. It is...
They seem to have a plastic gear built in as protection for overloading (prob). When the machine counters to much resistance that gear will strip its teeth causing the machine to not be able to turn, that it what seems to be the grinding problem. If it is not the plastic gear then it another gear that is "stripped(of its "teeth") I hope your problem is not a severe, but if your mixer is "locked up" then at least you found the problem.
Jan 12, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Hobart mixer making grinding noise
the noise is not a good sign. would rec. taking apart trans. and investigate gears,shafts, before futher damage takes place
Nov 30, 2009 | Hobart D340-6009 Mixer
My mixer is making a grinding sound. I had it serviced a few years ago, because the gears sounded like they were slipping when making bread doughs. The service center said it only needed an oil change....
Its worth fixing but having someone who specializes in your product is the key, these machines are wonderful products and engineered great. I would say if your mechanically inclined jump on inside the machine and see whats going on, but if your NOT send unit to us USPS it's not that expensive plus you would only have to pay oneway, we will take care of the shipping from our side,,estimated cost $29.00-$49.00
Nov 13, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Grinding Noise
If it's metallic sound you are loosing teeth on a gear or two.  This is caused by lack of lubricant or simply fatigue of the material of the gears.  Don't use it, you can get metal flakes in your food.
Take it in to a repair shop and have it fixed.  The money spent is well worth it because if done correctly will last another 12 years.
Oct 21, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Kitcchen Aid mixer making a grinding noise
common problem. Worm gear & bracket #PS734273 about $36.
Oct 21, 2007 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
271 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
