Question about Microsoft Xbox 360 Console
Xbox 360 not reading discs
My xbox 360 is not reading discs anymore. I tried a few games in a friends xbox and they worked perfectly fine. What should I do to fix this?
  • Microsoft Master
  • 441 Answers
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
Posted on Nov 17, 2009
Mmy x box 360 cant read my game what should i do
This is a common problem with old xbox 360 consoles.If your console is still under warranty, try getting a replacement by visiting the support website at xbox.com/support.
If you are no longer covered by insurance you can do an old trick I used to do with my old xbox 360.
Open the disc tray and insert the disc, as soon as you insert the disc in the console, hit your xbox on the top surface a few times, around 3, by this I mean slap it. it might take a few tries but it worked me.
However, if you are having problems with a specific disc, you should try cleaning the disc with a clean cloth. If that doesn't work, you can borrow the same game from a friend or try to obtain a temporary copy. Download the game to your hard drive and insert the original game, it should work flawlessly.
May 22, 2011 | Video Game Consoles & Games
Why won't the xbox read any disk after installing the xbox live
Mar 09, 2011 | Video Game Consoles & Games
Have xbox 360, and new fallout 3 game of the year!!! play the game for 2 weeks ,the game loads, but when you start to move your character the game goes to blue screen or says it can't read disc!! and goes...
if it just has scratches then spread toothpaste all around it dry then wash it off with water and dry it completely but if it has a perfect scratched circle then u gotta replace it cause if it has that circle it wont work anymore, thats why gamestop has a new deal for a few more dollars that if that circle happens they replace it for free
Mar 31, 2010 | Microsoft Xbox 360 Console
My xbox has been put together from two xbox's(one of which had broken and the other that was fine but was lacking hard drive and other acessories.)So, I put both of them together and it works fine. Except...
This forum might be able to help you:http://www.xbox360forum.com/forum/xbox-360-console/72481-replacing-360-cd-drive.html You can also google on how to flash your drive.
Nov 30, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont read some discs
if its out of warranty you could open it and clean the lense with q-tip and rubbing alcohol- otherwise try game stop for a cleaning kit
Aug 06, 2009 | Microsoft Xbox 360 Console
Xbox 360 reads games, doesn't read games?!?!
Sounds like your laser has been knocked out of alignment. Contact MS or look for someone who knows how to align them
Mar 25, 2009 | Microsoft Xbox 360 Console
Xbox 360 open tray prolem, for only 1 game, which works fine on--
well creamy peanut butter will clean it good or tooth paiste it may help
Mar 11, 2009 | Microsoft Xbox 360 Console
System won't read games and makes buzzing noise
Is it a copied disk? this only happens to those types of disk. Try contacting Microsoft.
Dec 23, 2008 | Microsoft Xbox 360 Console
XBOX 360 disc reading problem
Yes! you can contact Mircrosoft, the number can be found on the box that your 360 came in... call them and let them know that your Xbox no longer reads disks and they will send you a box in which you can send them your Xbox and they will repair it and send it back to you Free of Charge! It takes a few weeks to a month to get your 360 back, but it's worth the wait when it's working perfect again!
Hope this helps :)
May 17, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
814 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
