Question about Philips Magnavox 20MS233S 20" TV
I can not get the tv to go above channel 38 when pressing the channel up button on the remote. I can get higher channels by pressing individual channel numbers, but not with the Channel Up button. I have lost the manual
  • 317 Answers
Press menu and select scan channels automatically....make sure tv is set to cable not air
Posted on Nov 17, 2009
I pressed a button by mistake and my Sony tv has no picture. Now has small box left hand upper corner with A and lines like wifi icon
Try the RETURN button on the remote to get back to viewing.
Get the manual at Sony KDL 40S2010 Manuals See page 11 for remote control keys and page 38 for further trouble shooting if necessary
Jun 03, 2016 | Sony BRAVIA KDL-40S2010 40 in. LCD...
HI, just brought a Panasonic TX-P50U30E but HAVING PROBLEMS GETTING THE SA\ME CHA\NNELS I USED TO HAVE ON MY OLD TV ! i live in Gibraltar
Sounds like your auto programming needs to be set there should be a option in your menu to scan available channels and even add them manually. I must ask are you getting cable service thru a box or strait thru coax?
Sep 05, 2011 | Panasonic Televison & Video
Can set up th remote control for this tv with the direct tv cable remote
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 05, 2011 | Curtis LCD2425A TV
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
My admiral tv 32 inc goj12390 dont have the remote control and i cant see the dvd on tv scren beacause is only on chanel 3, 4 and i can put it on aux or imput
This worked for my Admiral TV model GRD15272:
Using the buttons on the TV, go to the setup menu, and scroll to "editchannels" by pressing "setup" button until "edit channels" ishighlighted. Then, using the channel up/down buttons, go to channel 91and press + volume. This should add the video input2_bing.gif to your channels. 92 is S-video. It is helpful to have what ever device (dvd player or game console) hooked up and powered on, so you know when you are on the right channel, but it should be 91.
Mar 08, 2010 | Televison & Video
I HAVE MISPLACED MY MANUAL AND CAN'T FIGURE OUT HOW TO DELETE UNWANTED CHA NNELS AND OR BOX WHICH OFFERS DELETE ALL, DIGITAL,ETC.
To delete unwanted channels, hit the menu button on the remote or the right side of the front TV control buttons. Go to TV/HDTV Setting and the Channel Edit function. Choose delete. A pdf of the manual is available:
http://www.westinghousedigital.com/pdf/49_User_Manual.pdf
I hope this helps.
Feb 14, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Due to analogue tv channel 5 being swithched off, need to retune syncmaster 225md. please help....
found button on remote (d.cha) - digital channel and did auto search.
All channels found and is working fine.
thankyou
Mar 25, 2009 | Televison & Video
I am trying to program a one for all remote urc 3220 to be able to change cha nnels on my panasonic tv/vcr pv-m2058 for dish. right now i can only get channels 44 and 87
URC-3220 One for All Big Easy 3 Universal Remote
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Panasonic TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Mar 17, 2009 | One For All URC4110 Remote Control
I am trying to get channels above 13. I do not
Try bringing up the menu by holding both volume buttons down at the same time (or use menu button on remote if you have it). Go into CH SET using the channel and volume buttons on the front of set (or use the SET + and - and the ENTER buttons on remote). Go to the TV CATV line and move the arrow to CATV. Let menu time out. This will put tv into cable mode. Hope this helps.
Mar 12, 2009 | Durabrand DU1901 TV
Channel search for my Phillips PL9125
You should contact to get original remote for that TV.
Nov 05, 2008 | Philips Televison & Video
Philips Magnavox 20MS233S 20" TV Logo
114 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
