Question about Saeco Odea Giro Plus Coffee Maker
Our machine has stopped working....the alarm light is on and flashing slowly so we have gone thru all the steps in the book to find out what is wrong. When we turn the machine on, the green lite goes on for a second then goes off and the red light starts flashing somewhat slowly......we are getting panicky...any suggestions. Thanks in advance for your assistance.
  • 20 Answers
If red light slowly flashing....Please check brewunit,dregdraw, door and coffeebean lid is properly in .
If flashing fast..means ventilate(prime the machine)
If itis steady..no water in the tank or time to empty the drip tray.or the more serious case the grinder is not working or not self testing.
Posted on Dec 08, 2009
Jeep Grand Cherokee 2004 alarm dash light flashing quickly and every morning alarm sounds at about 6am. Light used to flash about every 10 seconds.
well it needs service,
the VTA is complex.
read this chapter, first. or get car serviced.
my guess is there is a bad door switch. (common)
using the metal key part, is in the operators guide
this mode , (key metal ) disables the alarm system, a feature of it.
if you have a EVIC display in the dash cluster, it tells you which door s failing, lacking that, it takes a scan tool to learn that.
if the horn honks 3 times when open the door. that means
it tripped while your were gone, (door switches tripped)
here are the links to the free books
the operators guide (2004 get it before 2018 or its gone)
http://owners.mopar.ca/en/
if really curious how it works. see this.
click WJ
then click veh, theft and security
bingo the whole ball of wax. chapter 8Q from JEEP,
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
Jan 09, 2017 | Jeep Cars & Trucks
Paper stops half way
Please check for torn piece in the carriage which is causing the error
Jul 06, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Machine stopped - alarm light flashing
just saw this yesterday. remove the top rear paper guide. on the left side between the tractor feed and the input slot for the paper, there is a sensor flag that pivots. check for paper scrap caught under the flag. it prevents the flag movement, causes a paper out alarm.
Jul 13, 2012 | OKI MicroLine 420 Matrix Printer
I have a red light and nothing is working no cofee and no milk nothing
I have a Saeco Easy. Maybe the solution for my machine will help you. You did not specify which light is red I will assume it is the "Alarm" light.
Alarm light (looks like an "!" exclamation point)
• permanently on: signals the machine is out of coffee, the water tank is
empty, the drip tray is full or the dregdrawer is full.
• slowly flashing: signals that the brew group is not inserted, the dregdrawer
is not inserted, the coffee bean hopper lid is not on, the service door is open
or the steam/hot water knob is not correctly turned to the desired position.
• quickly flashing: signals the need to prime the water circuit
Apr 19, 2011 | Saeco Talea Giro Espresso Machine
Alarm is sounding
replace the memory card of your computer.
Feb 27, 2010 | E-Machines eMachines Desktop PC
2005 honda odyssey homelink programming
If you just received your vehicle and have not trained any of the buttons in HomeLink before, you should erase any previously learned codes before training the first button. To do this, press and hold the two
outside buttons on the HomeLink Transceiver for about 20 seconds, or
until the red indicator flashes.
Release the buttons, then go to step 1.
If you are training the second or third buttons, go directly to step 1.
1. Unplug the garage door opener motor from the electrical outlet.
2. Hold the end of the garage door opener remote 2 to 5 inches from HomeLink. Make sure you are not blocking your view of the red indicator in HomeLink.
3. Press and hold the remote transmitter button and one of the HomeLink buttons at the same time.
If the red indicator in HomeLink begins to flash slowly at first, then rapidly, release both buttons, and go to step 5. If the red indictor in HomeLink continues to flash slowly (does not flash rapidly), your remote transmitter may stop transmitting after a short time. Go to step 4.
4. Press and hold the remote transmitter button and one of the HomeLink buttons at the same
time. While continuing to hold the HomeLink button, press and release the remote transmitter button every 2 seconds. If the red indicator in HomeLink begins to flash slowly at first, then rapidly, release both buttons, and go to step 5. If the red indicator in HomeLink continues to flash slowly (does not begin to flash rapidly), repeat steps 2 thru 4.
5. Plug in the garage door opener motor, then test the HomeLink button by pushing it for about 1
second. If the button works, programming is complete. If the button does not work go to step 6.
6. Push and hold the HomeLink button for a few seconds, then watch the red indicator on HomeLink.
If the indicator stays on or flashes slowly, repeat steps 2 thru 5. If the indicator flashes rapidly
for 2 seconds then stays on, you have a rolling code transmitter. Go “Training with a Rolling Code System”
7. two HomeLink buttons to operate any other compatible remotely controlled devices around your
home (lighting, automatic gate, security system, etc.).
Repeat these steps to train the other
Jan 05, 2010 | 2006 Honda Odyssey
First: alarm went off on its own.(mazda 6 2003). Now when locking and unlocking car sometimes indicators flash and sometimes not. Now red immobaliser light is flashing on dash when driving, then stops...
there is often a small back up battery in the immobiliser unit itself, if you can locate this unit and replace the battery with the ignition on / engine running, then it should not need recoding and work fine after that. The other thing that could be wrong is the key battery (if the fob has one) or the transponder chip in the key head. If the key signal is low the immobiliser lamp will light during driving, but this does not explain the alarm going off. That is more likely either a poor vehicle battery, alarm / immobiliser back up battery, or another electrical fault such as water leakage into a tail-light or even the alarm unit itself when it rains. A lot of alarms are voltage sensing and when the vehicle is parked they will alarm if the battery voltage changes for any reason, though not during driving so the battery in the immob is my first choice to look at.
Oct 24, 2009 | 2003 Mazda Mazda6
Alarm light slowly flashing and will not stop
Try this remove the drain tray,dregs tray and brew unit. Clean the rails that the brew unit slides on, check the gear next to the handle of unit to make sure arrow is on the N. Then re-insert unit and trays.
May 31, 2009 | Saeco Talea Giro Espresso Machine
ELECTRICAL MISTERY
Here's a first step: Put key in ignition, turn on but do not start car. When dash lights up, the alarm light will flash if it has been triggered. If this alarm light is flashing, you have set off the alarm. Here's how to reset it: Leave key on, and let the thing flash for five minutes or so. Finally it will stop flashing on its own. Now start the car. If it runs ok. Kill it and turn key back on to check if light has stopped its flashing. This may be way off, but that is the reset procedure for alarms on those blazers. Man I've seen a bunch of them in my shop this year!!!
Mar 20, 2009 | 1996 Chevrolet Blazer
Display lights flash
I have just posted the same problem about the lights flashing rapidly, I have just gone to investigate my machine and switched it off and on again at the mains and so far it has resolved the problem. Hope this works for you.
Mar 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Saeco Odea Giro Plus Coffee Maker Logo
1,713 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
