Question about Kenmore HE2 Plus Front Load Washer
My washer will not drain. I get what looks like an F2 error message I have followed the manual instructions to restart the machine ... hitting "second rinse" etc. Nothing. This machine is not old at all ... less than 3 years old.
    Scholar:
  • 86 Answers
There should be three screws in the bottom panel of the washer. Remove the screws and the pull panel down and off. There should be a clean out drain on the pump - so,...you're gonna need a bucket. Hope this helps...(and good luck).
Posted on Nov 17, 2009
I am getting a random F2 error on my Whirlpool Duet Washer. I can hit cancel, restart and eventually get through the cycle. I have removed the pump and cleaned it as well as all of the lines (with a...
Error Code F02 means a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line.
To check the drain pump, click on the following guide link: checking_drain_pump_kenmore_elite_front
Generally this coudl be the firsdt steps:
a. Check the drain hose to make sure it is not kinked or clogged.
b. Check the electrical connections to the pump and ensure the pump is running.
c. Remove the drain pump filter and check for foreign objects and/or debris.
Hope this helps (remember to rate this answer).
May 13, 2011 | Washing Machines
F2 error code shows up on the panel with 2 Min's left on spin cycle, have difficulty to reset machine for restart
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
(courtesy JSRock)
Thanks for using FixYa!!
Dec 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer, model number GHW9100LW2, is stopping when it gets to the drain/rinse cycle and showing an error message F2 on the display. What does the F2 error message mean?
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I'm getting An F2 message on my washer followed by a beep. The washer is not draining correctly.
F2 is a suds problem.
There is an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. Once a month, run the machine on the hot water cycle with a cup of bleach. This will clear out any suds build-up. Good luck :)
Jul 13, 2009 | Kenmore Washing Machines
F2 My washer freezes during mid cycle
"F02" is a Long Drain error code, which usually means you have an obstruction in the drain pump, drain lines, or the drain pump has failed. If the drain pump will not function, the washer will not complete, or restart a cycle. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Sometimes you may also get a "SUD" error in conjunction with this error due to the detection of air in the drain pump (lack of water flow). If cleaning the drain pump reservoir, and checking all the drain hoses does not correct the problem, you may have a failed drain pump.
Replacement pumps can be purchased on line at searspartsdirect.com, appliancepartspros.com, repairclinic.com or pcappliancerepair.com. All these sites offer competitive pricing so shop all of them for the best price.
If you have any questions about this repair please let me know. I hope this helps you.
Jul 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Machine doesn't drain, ticking noise.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 11, 2009 | Kenmore HE2 Plus Front Load Washer
F2 Error - Load not finished
It was a clogged drain. Cleared out the drain hose and the machine restarted at the beginning.
Mar 27, 2009 | Kenmore Washing Machines
Washer will not spin to finish cycle
Mar 17, 2009 | Kenmore Washing Machines
I have a kenmore elite he4t washer and dryer, the washer will not finish a load. It makes 5 or 6 loud beeps and then flashes error messages. like sud, or f2, it's really frustrating.
Jan 06, 2009 | Kenmore 46462 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
125 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
