Question about GE WDSR2080D Top Load Washer
Model#wdsr2080d5ww serial#rg118515g worked fine until yesterday, leaking water on floor at front left [about a quart] same today, tipped over,took back off,no wet areas.pieces of insulation at bottom. What do you think? thanks
  • 68 Answers
Should be able to remove front while it's standing in place. If there's not two screws on the front bottom, it will have two push clips about a third of the way in on either side between top and front. Push in gently with a standard screwdriver on the clip while tugging on top corner of front.
Posted on Nov 17, 2009
What does EFO mean
Its an anti flood warning. generally it means something has leaked into the cabinet and water has triggered the safety float on the floor of the cabinet. You will probably find a small leak somewhere which has allowed water to gather under the machine. IE/ Hose, front gasket, pump etc.. If you tip the machine backwards to drain all the water out of the base, it will probably work until the safety switch triggers again. Locate and fix the leak before it gets worse and causes some damage.
Mar 08, 2015 | AEG Washing Machines
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Intermittent water observed under machine
Difficult if not seen. Most common water on the floor senario is a drain pump leaking:or a perrished pipe from friction.or sometimes, water backs up from the house drainage system due to a restriction.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Trunk water leak 1993 buick park avenue
Mother nature is too slow in finding leaks. Have someone small get in the trunk with a flashligh and watch as you run a hose over everything. LET THE PERSON OUT!
Jun 11, 2009 | 1993 Buick Park Avenue
Water Leaking on floor.
probably the water dispenser valve.
Apr 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
Whirlpool washer leak
Regarding those Cabrio washers that are leaking, while I own the WTW6600 model and have never experienced any leaking, I was told by the service repairman who came out yesterday that there was a flash bulletin sent out by Whirlpool that the fix is in the form of a new inner plastic section. I don't know the technical terms but I saw the bulletin on his computer screen. He mentioned that some people had reported that water was on the left side front of the floor and was being caused by when the water flows through the top section where you pour the liquid detergent, on some models, the water would splash over. He was able to show me the redesigned piece that was being put in to replace those that have the problem. If you are experiencing a problem with water leaking from the unit, and it appears to be in the front, left side area, this could be something covered under that service bulletin.
Sep 01, 2007 | Washing Machines
Leaking water
test: first, turn off water supply to frig. then dry up all water. then ensure frig is running at right temperature. now gradually turn on water and observe where leak is. My guess is it is overflowing the ice-maker. there is an adjustment for this. pop off the cover over the end of the ice-maker. look for a screw adjustment. turn it counterclockwise.
Jun 04, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Flooding
La Trisha, There could be many reasons for the leak, however usually all leaks are visable. Your model is a direct drive pump and motor and I have seen a lot of these pumps go bad and leak. You will have to remove the front panel. There should be 2 clips, one on each side of the washer top. Push a putty knife in these clips and the front panel should pop out from the top. Now you will be looking right at the pump on the bottom. It is held on with 2 clips and 2 clamps, a real easy fix. When you remove the front panel, let the washer fill a little again and see if the water is pouring from the pump. You will also be able to get a look at all the other hose attachments. The part number for the pump is 3363394. Good luck..
Jun 17, 2006 | Whirlpool LTE5243D Top Load Stacked...
GE WDSR2080D Top Load Washer Logo
199 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
