Question about Viking 37 in. VGSU161 Gas Cooktop
Viking 37 in. VGSU161 Gas Cooktop looking to replace the grates any help?
  • 491 Answers
LOCATE A SECOND HAND GAS OVEN STORE AND LOOK FOR ANY GRATES I AM SURE THE OWNER CAN LOCATE GRATES FOR YOU GOOD LUCK.
Posted on Nov 17, 2009
Removing spark module viking gas cooktop
Usually any control knob will activate all four igniters it's usually a faulty pressure switch rather than the igniter pack module.
Apr 01, 2014 | Viking 37 in. VGSU161 Gas Cooktop
No clicking noise when I try to light any burner
Check power to cooktop first to assure it is not the issue. If not the issue, the spark module is the cause of all the burners not working. If only one burners its a burner switch, if more than one burner its the module that needed replaced.
I hope this helps.
Aug 10, 2013 | Viking 37 in. VGSU161 Gas Cooktop
The unit continually sparks even the gas is turned off. What part do I need? Is this an easy job?
Hi stevebauman,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 20, 2011 | Viking 37 in. VGSU161 Gas Cooktop
All six of the ignitors on my vgsu161bss cooktop are not firing--- electrical supply is working
Hi There are a few things to check for: First make sure the electrode (the small metal piece that the spark comes ...or The water that you spilled onto the cooktop has shorted out the ignition switch in the gas control knob. Don't worry .
Aug 16, 2011 | Viking 37 in. VGSU161 Gas Cooktop
11 year old Viking VGSU161-6BSS with intermittent gas smell.
STOP USING COOKTOP AND TURN OFF GAS AND GET SOMEONE AUTHORIZED IN AS SOON AS POSIBLE .
Oct 22, 2009 | Viking 37 in. VGSU161 Gas Cooktop
Two of the 6 knobs on my gas cooktop are stuck and will not depress or turn.
Pull the knobs off
Spray some WD40 or release oil on the shafts , wrap a piece of tissue around them first to alow the stuff to soak in
Give it a couple of houts then get a pair of pliers and gently lift them up and down until the come free
If need be apply some more WD40 as you do that
Oct 20, 2009 | Viking 37 in. VGSU161 Gas Cooktop
Viking gas cooktop vgsu161-6b sparks continuously. There is no gas leaking. I spilled water on the controls and it is only when I turn on the 3rd knob from the top that this happens.
The water that you spilled onto the cooktop has shorted out the ignition switch in the gas control knob. Don't worry though no permanent damage has been done. Leave it unplugged from the electrical outlet for a day or two until the liquid dries out. You can manually light the burners with matches or a BBQ lighter in the meantime. If you want to try and speed up the drying process you can use a hair dryer.
Same thing, can't figure out how to get it apart.
Viking has a "special" (ha,ha) tool that you put across those 2 notches in the center brass ring. You can find this wrench with pics at: allvikingparts.com/BT_SBW_Sealed_Burner_Wrench_s/138.htm
You probably have thrown out many similar looking 'free' wrenches(because we have better ones in our toolbox) that are packaged with kids toys etc. that should do the job.
A hand held steamer has done a pretty good job for me in cleaning the burned on gunk. I have also used my dremel with various different polishing tips when I have been really frustrated with gunk and discoloration.
Aug 26, 2009 | Viking 37 in. VGSU161 Gas Cooktop
Viking range - no way to simmer
There is a conversion kit to convert the range from natural gas to propane, it is possible that it was not installed or not installed at the time of purchase. There is a part in the regulator that has to be switched from one gas type to another as well as individual burner orafices that have to be changed. You should have the point of purchase service verify that this has been done correctly. The complete information should be in your owners and installation manual or available directly from the viking website.
Nov 19, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Viking 37 in. VGSU161 Gas Cooktop Logo
204 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
