Question about Milwaukee 49 19 0026 Tape Measure 25' In/Metric
Just bought a 12"sliding dual bevel miter saw with stand (# 48-08-0550)One of the 4 nuts used to attach the saw to the stand will not accept the bolt provided.Perhaps it was not welded straight onto the sliding plate. Solution ???
  • 10,865 Answers
Hello. Do this. Loosen the other three nuts so there is lots of wiggle room and then get the fourth nut and bolt started. If it will not start at all, check it against the others as it is possible that the company merely sent the wrong one. If that is the case, take one of the good pairs to any hardware or even home depot and match it up.
The other option is to purchase the thread cutter of the correct size and recut the threads.
Posted on Nov 17, 2009
Bosch Glide Miter Saw get stuck at 45 degree bevel to the left
Adjusting the miter angle involves two cast surfaces sliding against each other. If those surfaces have some irregularities, high spots on the two surfaces will bind against each other. You may have to disassemble the rotating table from the base and do some filing or grinding.
Dec 29, 2013 | Makita Tools 12" Compound Miter Saw -...
Dewalt 12 inch compound sliding miter saw
This saw has locking indexing to set bevels for 52 degree crown molding the other common crown angle is 45 degrees, the bevel setting needs to be other than where the locking indexs are for the 52 degree crown. Problem is that the bevel lock does not securely hold at the bevel angle required. Is their an adjustment to get this lock to hold tighter.
Jan 04, 2012 | Dewalt 12" Beveling Sliding Compound Miter...
My blade is not square to the table i,e if I make a 90deg cut, it is about 1/16 wider at the top of the board than it is at the bottom. I've lost my owners manual and was wowndereing holw I go about...
Set your saw square using a combination square if you have one. Then to to adjust the saw to stay square there should be a gold coloured nut that you can adjust on the right side below the lever you use to unlock the saw when setting what angles you want to cut. Either move it in or out to get the proper setting. Hopefully this answers your question.
Apr 25, 2011 | Makita 10" Dual Bevel Sliding Compound...
Which bolts do i loosen to adjust the 45% angle of my blade? Ive already squared up my blade by using a square and laid it down on the deck and squared the back rail like that> but how do i square...
To adjust the bevel, (blade angle), loosen the black lever at the back of the unit, tilt the blade housing using the handle (this may require a fair bit of force) until the arrow on the scale is at 45 degrees then tighten the black lever.
Dec 26, 2010 | Makita LS1214F 15 Amp 12 Inch Dual Bevel...
Looking for help scouts have a carpentry merit badge from the 50s they talk about using a BEVEl and a Miter tools can you help
The bevel is an angle fiding tool. it consists of a wooden section about 4" long with a swivel bolt at one end connected to a slotted metal blade (similar to a 1 foot steel ruler). The bolt has a wing nut and bolt to allow loosenig to allow the blade to rotate and slide to the required angle where it is locked into position using the wing nut.
The mitre is a wooden block with slots cut into it at pre determined angles. ie 45 degrees. When cutting a mitre joint the wood is placed against the block and the saw follows the line of the slot cutting the 45 degree angle.
Hope this makes sense and good luck
Feb 18, 2010 | Bosch 12" Dual - Bevel Compound Miter Saw...
Can't change mitre angle
you need to remove the guide fence with the screws on the back. then you remove the throat plate and there is the bolt is that keeps it all together.
Just took one apart last week, not really difficult
Dec 26, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
How do you swap out the c12 fch hitachi blade
all you do is pull the gard up you will see a bolt on the left side using a 9/16 rench pull it to you remove the bolt blade comes off . on some you need to take the gard off it has one screw on it that will be on the right side as well... good luck..
Aug 16, 2009 | Hitachi C12FDH 12" Dual Bevel Miter Saw...
The vertical blade stop is not true vertical. What adjustments are there to adjust the stop?
If you look on the back of the saw where the pivot is, there should be a bolt on either side that should adjust how much bevel there is . As for a 90 degree angle, there should be a locking pin or stop to keep it from leaning out of square. Be sure that it is accepting the pin properly and that it is clean. Not sure if there is an adjustment on the sliding saw, but i know there wasn't on my dual compound mitre saw
Jul 26, 2009 | Makita 10" Dual Slide Compound Miter Saw...
Craftsman 10-in. sliding compound miter saw
there should be a safety latch on the right ..down by the base or at the back you should have to press down on the saw to release it.hope that helps..
Jan 13, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Milwaukee 49 19 0026 Tape Measure 25' In/Metric Logo
57 people viewed this question
Top Milwaukee Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Milwaukee Measuring Tool and Sensor Expert? Answer questions, earn points and help others
