Question about Hitachi 61UWX10B 61" Rear Projection Television
The colors are not aligning correctly. I have tried to use the magic focus but it still did not align.
  • 566 Answers
You have a convergence problem. Go into the menu and you should find a convergence alignment menu, try to align it there, if you can`t then you probably need local help from a tv repairman. good luck
Posted on Nov 17, 2009
Magic focus not working colors not aligning
If Magic focus will not correct it (it is the limited auto convergence for this set) both the convergence chips which should be stk392-110 or 150 will have to be replaced, convergence is done with the original remote with set in the Decam ( tech convergence mode).
The parts are not that expensive and TVrpairparts.com sells kits with instructions for these sets by model number.
Dec 10, 2012 | Hitachi 51S500 51" Rear Projection...
Magic focus will not realign color. Red lines will not line up
Red Gun is out of alignment, need a tech to align color guns>
Feb 02, 2010 | Hitachi 57F500 57" Rear Projection...
I purchased a tv repair kit and replaced the convergence ic chips to fix my convergence problem. put everything back together and now, no picture. I tried magic focus and it works great, the colors are...
As per statement, "the magic focus works great, the colors are bright and aligned" it means the tubes are working ..you need feed a signal to see the picture...the tv video goes muted without signal
Dec 29, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Turned on TV this morning and the colors were out of alignment. TV works just looks funny. Tried the magic focus and got most of the screen lined up....except the upper left hand corner where the colors...
There is a convergence output kit for this set. There are probably resistors in the convergence circuit that are starting to loose there values. If you are going to have the set worked on have them install the whole kit which includes the convergence outputs and resistors. Thanks
Oct 27, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 43fwx20b magic focus the 3 colors are not adjust.
First have the convergence IC's replaced these are the two large black IC's mounted on an metal heat sink.
Oct 24, 2009 | Hitachi 43FWX20B 43" Rear Projection...
My blue color is out of alignment. I tried
There are integrated ic's that control the convergence circuit, it generally requires qualified service personnel to repair this.
Jun 28, 2009 | Hitachi 57F500 57" Rear Projection...
Yellow and blue color ruins total picture on 50" tv,can't get rid
lupe0112,
I'm no expert, but I think that you have a problem with the convergence of the 3 color guns. I've been working on a similar problem. As a first step, have you tried "Magic Focus?" The Magic Focus button for the Hitachi 53UDX10B is at the left of the small front panel controls that also include your RCA composite and SVideo connectors. Let the set warm up for about 20 minutes (as recommended by the user guide), and then press the Magic Focus button. When you press the Magic focus button, the set will auto align the 3 color guns. If this doesn't fix your problem, unplug the TV for at least 4 hours and try again.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Colors are separated on the top from the left to right
Probably the color convergence is off. I had a similar problem. Have you tried the magic focus button yet? That is located at left in the small front control panel. Power on TV, wait 20 min (according to user guide), then press the magic focus. If that doesn't fix the problem, you could try the service mode alignment procedure. But that's a little trickier. I don't have a link handy for that procedure right now, but will look for it if magic focus doesn't re-align your color convergence.
Jan 02, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Color Alignment
get a shop manual,it tells how to do the whole convergence process and how to store it to the rom memory to save it.
Mar 15, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 61UWX10B 61" Rear Projection Television Logo
124 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
