Question about AudioBahn AW121T Car Subwoofer
I just bought an Uudiobahn AW121T and I am trying to figure out the best and loudest box for the sub
    Problem Solver:
  • 8 Answers
Ported pro boxes are all ways the best way to go make sure they are ported get the blk plastic ones they are the best in the pro line
Posted on Nov 17, 2009
Tralaua soundstream 15in 1000 rms best way to wire subs for loudest sound
Best thing to do is build the right enclosure. Which woofer exactly as you need the Theile/Small parameters to calculate the correct vented enclosure. That will buy you more than any wiring setup. Typically 15 icnh woofers like to see about 5 cubic ft per woofer to really get loud. And it all depends on your vehicle also. Need more input to help out, like what amplifier, whioch woofer specifically, vehicle your putting it into.
Jun 02, 2014 | Car Audio & Video
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
Which subwoofer will sound the loudest?
When you're looking for a loud subwoofer you'll need to consider sensitivity, enclosure type and available power. You'll need to start with a subwoofer with a high efficiency (sensitivity) rating housed in a ported or band pass box.
Power the sub with an amplifier that has a power output that is within your sub's recommended power range. You'll achieve the slam you're listening for. Using an amplifier with a bass boost control can also help.
Jul 29, 2012 | Furniture
I have a alpine type r 12 in a seald box and want to know how to adjust my amp to sound right with metal and rock
hard to do because it is a VERY loud sub. turn the frequency down low on the amp so as just to be able to hear the kickdrum and bass line and turn the gain up just loud enough where you can hear it comfortably ( to your taste) at the loudest volume your going to listen to it at. if you do it right itll sound good. if you turn gain up past half or more it might blow your sub so be careful.
Sep 12, 2011 | Hifonics BRZ17001D Car Amp
Need to know how to wire my system ...I have the infinity reference series 611a I was told it was a mono block but it has two channels on the exterrior...also I have two 12 inch MTX thunder dual voice coil...
it all depends on what kind of box the mtx subs are in as far as wiring the subs. The best way would be take the speaker wire from both sub boxes and run the positive into the right positive then the negative into the left negative. and run 8 gauge wiring kit to the amp because 10 might be to small and 4 is to big 8 gauge is perfect for this amp.
Jul 18, 2010 | Infinity Reference 611a Car Audio...
I have a 12W7 jl sub with no enclosure or amp.
Hello cdoran93,
Well, "best" and "loudest" are mutually exclusive. You can configure for one or the other, but not both at the same time.
The best (most accurate) bass is produced from a sealed enclosure, while the loudest (highest spl) is produced from a properly tuned ported enclosure. The recommended sealed box volume is 1.375 Cu.Ft. Ported is 1.75 Cu.Ft. For a ported enclosure, you need to decide what frequency to tune it for and then look at the JL specifications to the size of the port.
www.crutchfield.com has both types of enclosures at prices starting around $70.
Hope this helps.
May 11, 2009 | Jl Audio 12W7 Car Subwoofer
Need to build a ported sub box for my alpine swr-1222d subs x 2
Try going to Alpine web site, I think they have box building program as well that you just input your sub models into and it gives you blueprints for various types of enclosures. I know Rockford has one and a comparative attachment to compare equipt specs. Or if you call Alpine headquarters you may be able to get info that way, I once sweet talked a rep @ a demo vehicle I met doing some car shows that turned me on to a senior rep @ Korbon Trading the owners of Rockford Fosgate and they gave me specs for a 5 stage band pass box for some competition subs that was more intricate and detailed than anyone before that could find me, Won me first place in spl. Matching your box specs to your subs is crucial and the best specs are often kept a secret for demo competition vehicles! So ask around with some competition guys or other top experts if your real serious about your boooom.
Mar 13, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Just wondering ..
square port (slot loaded) vented box tuned at 33 - 38 hz is the loudest deepest bass you can get
Nov 18, 2008 | AudioBahn A2801Q Car Audio Amplifier
Best results
huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
Jul 09, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Audiobahn sub settup
audiobahn.com has a tech support with diagrams on thier website check it out
Jun 03, 2008 | AudioBahn AW121T Car Subwoofer
AudioBahn AW121T Car Subwoofer Logo
82 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
