Question about Nextar X3-03 Car GPS Receiver
My Nextar X3-01 sometimes has misses such as: one area near my home always indicates off road, also on a recent trip i found my unit directed me off road for no apparant reason, also the unit will not accept my home address. Is an update available and would an update correct these problems.Otherwise the product has been an immense assistance in locating remote addresses.
    Top Expert:
  • Nextar Master
  • 79,865 Answers
These are just the common errors in the programmed maps stored inside the unit, I have had a GPS for years and have had this happen many times to my suregrin, sent down dirt roads, routed around in circles and so on.
Posted on Nov 17, 2009
How do I update my Nextar x3-08 gps so the new roads will show up ?
visit Nextar.com to order your desired maps update and Check the overview description to see which SD card lists your GPS model number and serial number. Order the matching card.
Remove the existing SD card. This is usually found in a thin, rectangular slot on the side of the Nextar GPS.
Insert the SD card with the maps update into the empty SD card slot. Press until it clicks into place.
Reset the unit by pressing the "Reset" or pushing a pin into the "Reset" hole.
Click the "Navigation" button to have the maps automatically update on the GPS.
May 06, 2015 | Nextar X3-08 Car GPS Receiver
Whining Noise Near Rear Differential
indicates a fuel pump problem as that is the only thing in that area that is ignition controlled or possibly the EVAP system solenoid/ valve if it is in that area
the frequency will be constant as the pump rpm is constant
the noise could be a venting noise from the EVAP in in that area
the distance of 15 km indicates that the problem is heat related as it take that long for something to over heat and cause the noise
you may get an indicator by running the fault code
Dec 02, 2017 | 2001 Mercedes-Benz C-Class
My Ka alert has started going off quite frequently after 5 years (I've disabled X band). It is professionally hard wired in w/Valentine's connections and fuse. Happens on the same roads I've always...
have you tried to find out where on that same road it always goes off? could either be a new hidden camera or some other device recently installed utilising the same frequency as ka transmitting in that area. had same prob with my v1 always goes off in one part of the country road. even got out of car to investigate but found nothing that appears obvious.
Apr 24, 2011 | V1 Radar Detector
My Nextar GPS will not let me get step by step directions. A fatal application error comes up on the screen. When you read whats on the screen it says performed an illegal operation and will be shut down....
There are two things to try.
First try a unit reset. The process for doing a reset should be in the user manual near the back under trouble shooting. A reset will force it to reload the software. If it has become corrupted this will clear it on some units.
Next go to Nextar and look for a update or system patch. These are not the maps but the operating system patches. Usually these replace all the files and routines and fix things like your error. However the patches are not always available until well after a problem shows up. You should also contact Nextar support and see if they can help with either the patch/update or if you need help doing a hard reset.
If it is under warranty you can just send it in or exchange it. You may need to check with where you purchased or Nextar to find out if you are covered.If it is out of warrenty be careful as repairs can cost more than a new unit.
Jan 24, 2011 | Nextar Q4-04 Car GPS Receiver
I changed the fan motor because it had burnt. The capacitor was also changed. Recently, two months ago I had the unit serviced, which included the power washing of the inside and outside of the fins and...
Dear sir! First of all when water servicing any appliances,ask service man to check all loose wiring after service and also blow dry air near electrical ends to remove moisture or water drops.
And also replace compressor contactor (Not relay) as it's struck. That is one of the reasons to get breaker tripped. Helpful?
Jan 06, 2011 | Heating & Cooling
I have a GPS navigation system ITEM NO W3G-01 which was given to me. Can this be used in the United Kingdom? If not what can I do. I do not live in the States Or Canada. I live in LONDON, UK
In the product manual it indicates there is a SD card slot, along with a USB port, so there is a physical method to change the map data to your locale.
http://www.nextar.com/images/Product/W3G-01%20hardware%20manual-english.pdf
However, you should contact the manufacturer to see if their firmware allows you to change/add maps. Garmin GPS units have this capability, and I have used their topo & Road maps together with very good results for off-road adventures out in AZ & Utah.
Jul 13, 2009 | Nextar X4-T Car GPS Receiver
My nextar x4-t needs updated
my nextar x4-t need update bad can"t fine any it keep on tilling me that i need it
Apr 11, 2009 | Nextar X4-T Car GPS Receiver
Directional signals make vitually no audible when clicking
There is a turn signal switch device found under the dash that can sometimes be placed in an area that impedes the sound from reaching the driver. Turn the signal on while parked and in a safe area and listen for the source of the turn signal sound under the dash. Many times they are found along the steering column. Use a long screwdriver touched on the actual assembly and place the handle to your ear to verify that this is the correct assembly. If it is and it's not blocked somehow, check with a parts store for a replacement and tell the you would like one that has a substantially louder indicating sound. They should be able to accommodate and once replaced should resolve this safety issue.
Feb 11, 2009 | 2004 Toyota Highlander
Nextar gps update
Here is a proposed solution. We nextar owners who purchased this, not just for the low price, but for the many selling points. one of which is the ability to "update very soon". This constitutes a deceptive sales practice. Thereby, it is a fraud. This is illegal.
That leaves us consumers with one option. That option is to File a lawsuit against Nextar and their licenced retailers.
We need to band together, organize as a consumer group and either force nextar to comply, or we sue for the cost of a new unit from another company, plus punitive damages.
We as consumers can not continue to accept abuse like this from large corporations.
Nov 07, 2008 | Nextar Q3 GPS Receiver
Nextar X3-03 Car GPS Receiver Logo
113 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
