Question about RCA Televison & Video
Tv screen went white but can still see picture
Tv screen went white I can still see picture, but its as if the brightness is turned way up, even if I turn it all the way down
    Scholar:
  • 63 Answers
There is a defect in the video output circuit which feeds the signals to the picture tube. Unless you are technically inclined and adept at desoldering and part replacement this is a job for a technician. Often the video output i.c. fails and on some brands a resistor can open and cause this symptom also. One other possibility, with some TVs however, is that someone turned up the screen control. This control is accessible on some units through the back cover and is a service adjustment. Some units even had the control shaft projecting through the cover. If the screen control is there it usually is labeled along with the focus control. Adjust it until you get normal brightness. If this is not an option or it does not help you will need that technician.
Posted on Nov 17, 2009
I hooked up my cable box up to my sceptre tv and it had sounds but the picture is black and white I even went and bought the blue and green cords but still only black and white
With the blue/green/red cords (Component) you need to get a very good bright light on the connectors so you get the plugged into the correct COMPONENT connectors on the TV. Note, there are white and red AUDIO plugs right near the COMPONENT input so you need to be VERY careful. If you get it wrong, the colors on screen are often off and even black&white.
How is your cable box connected to the TV? Screw on "COAXIAL", Yellow, Red, White "RCA", single flat connector "HDMI" or 5 colored plugs 2 X Red, 1 X White, 1 X Blue, 1 X Green "COMPONENT"
Jan 08, 2014 | Televison & Video
SAMSUNG LCD TV very bright screen
hi Elle924.
this is all i could find out.
What kind of panel do you have - a LED or CCFL one? If it's CCFL then check the inverter board. The main board might be fine (changing the brightness settings changes the signal to the inverter board) but if the inverter board is faulty somewhere then the problem you described may be caused by it
or try this forum.
Why is my tv extremely bright Solved Other Consumer Electronics
or this one might help you.
White too bright in picture on Samsung LCD TV Forums
or even this link.
SAMSUNG LCD TV very bright screen Google Search
Nov 28, 2017 | Televison & Video
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
I have a hitachi rptv model #43FWX20B and the picture has a red tint to it. Opened back up and red green and blue bulbs light up. red bulb stays bright while blue and green go dim to bright as tv plays....
Howdy;
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Lost picture, sound fine Sanyo ds19310
are you seeing bright white lines along with blue colour please clarify so I can give you the best solution
Sep 12, 2007 | Sanyo DS19310 19" TV
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Some part of TV has been fused causing no picture on screen , only bright green horizontal lines , not even video channel could be set ,cannot see menu on screen please help by specifying possible...
if the screen is real bright green with thin small white lines in it its probably a shorted picture tube. Or a shorted Green driver Transistor. Good Luck
Apr 12, 2006 | Thomson 14MG135 14" TV
Televison & Video Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
