Question about Samsung SL30 Digital Camera
My SL30's lens is stuck. It is only about 3
My SL30's lens is stuck. It is only about 3 months old. Any suggestions on what to do to fix it?
  • 421 Answers
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Posted on Jan 23, 2010
How can I open the case of my Samsung SL30 camera?
I wouldn't try to open the camera lens to that extent to clean it out, you will have to disassemble dozens of tiny parts, springs, leaf shutters, tiny screws, gears, motor.....etc. It is rare that you get dirt inside the lens, maybe it is something else outside the lens?
Nov 25, 2015 | Samsung SL30 Digital Camera
The lens is stuck
try taking canned air to the lens joints.it could be just dirt or something blocking the sensor or the lens itself from retracting.
Aug 24, 2011 | Samsung SL30 Digital Camera
My Samsung SL30 Camera, are with the image blurred, and the Lens are stucked inside
The battery requires recharging else a new battery is required to replace a depleted once. Perform a power recharge of the device for several hours to attain full capacity. The camera lense should responde there after.
Jan 29, 2011 | Samsung SL30 Digital Camera
My samsung sl30's lens is stuck what do i do?
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries. (obvious I know).
2. The camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
Apr 17, 2010 | Samsung SL30 Digital Camera
My Camera have 3 months of use and now the lens don't save when i turn off. Works well, but i have to force the lens inside when i stop use it.
Don't force it, you'll break it.
You can try some of the fixes listed in this link as it's likely to just be a bit of dirt stuck in the mechanism, but given that the camera is only three months old it's fully covered by the manufacturer's warranty as long as there's no evidence that you have been clumsy or have tried repairing it yourself.
I hope that you get your camera working again and that you found my reply to be of use. If so, please rate my answer.
Feb 19, 2010 | Samsung SL30 Digital Camera
Canon SD100 Lens Error (camera)
First try calling 1-800-OK-CANON to see if warranty repair applies. If not...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 12, 2009 | Canon PowerShot SD1100 IS Digital Camera
Nikon CoolPix L18 getting lens error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Mar 29, 2009 | Nikon COOLPIX L18 Digital Camera
Coolpix L11
yep it's $100+ to get it fixed. i've read about this problem and it was fixed before, check this out.
http://www.fixya.com/support/t225788-fix_stuck_lens_nikon_coolpix_l11
good luck
Jun 24, 2008 | Nikon Coolpix L11 Digital Camera
Samsung SL30 Digital Camera Logo
332 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
