I live in Montreal which has quite cold winters. Was wondering if a dryer in an uninsulated shed off the back of my apartment would work/be effective?
    Scholar:
  • 86 Answers
Should be fine. Wow I would hate to do laundry at your place.
Posted on Nov 17, 2009
Have had two hoover vhv 680c tumble dryers from the coop electrical store. They have worked for two days exactly then when you go to use it again there is no power to the machine (replacement for each...
Purchased one of these tumble dryers on 20th Oct 2011 from Currys, yesterday morning no power whatsoever.
Have refused repair or replacement after seeing your similar problems and also after finding this review that indicates that these tumble dryers dont like the cold.
As many people like us have them in the garage, I'm not interested in one that needs it's own radiator and blanket !!!! grrrr ..
http://www.appliance-reviews.co.uk/p/Hoover-VHV680C-Vented-Tumble-Dryers-in-White-22491/reviews#tabs
Feb 28, 2011 | Dryers
Well my yfz 450 sat in my shed over the winter so i drain the tank and clean the carb. Then i went to start it and it wouldnt fire up. I took it apart and check it for spark from the coil and didnt have...
the ignition cant fail from sitting, perhaps the kill switch has corrroded, always put a spark plug in and ground it to the head when checking for spark , also check with a new spark plug
May 15, 2010 | 2004 Yamaha YZ 450 F
Washer location
Not advisable. Garage area would need to stay above freezing temp., and dryer performance will be poor at best if intake air is below 50 F. If you are not doing a lot of laundry, you can use a combo unit. (washer and dryer in one unit. LG makes one, others must also) They are slow, as the dryer is only 120 volt, and dryer does not work well with over a half load, but they also do not require an outside vent, and only require room for one unit, instead of a seperate washer and dryer.
Nov 09, 2009 | Washing Machines
Flat screen tv winter storage
HELLO
Your TV will be fine as long as it is kept at room temperature indoors and not inside a shed or similar outbuilding. Much warmer in a house, probably near freezing in a wooden shed.
Hope this helps you (:-)
Oct 17, 2009 | RCA L32HD31 32 in. LCD HDTV
Worried about winter storage
Extreme low temperature may effect the operation of the electronics, but unless you plan of using them in a freezing environment there will be no ill effects from the cold. These units are shipped in unheated trailers all over and routinely are exposed to freezing temperatures.
Thanks for using Fix Ya, please take the time to give this solution a Fix Ya rating.
clarkco
Feb 06, 2009 | Kenmore 44102 Front Load Washer
Black & Decker Cordless lawnmore CMM 1200 - battery
I bought my B&D cordless mower CMM1000 (very similar to the CMM1200) in April 2003. I made the mistake of following their instructions and stored it inside unplugged the first winter. Never again! The battery would not hold a charge April 2004, but was covered under warranty. Since then, I've left it trickle charging in the shed year round, including cold winters. No problem since then with the battery, which will last about 5 yrs before you need to replace it.
Nov 29, 2008 | Black & Decker 19" Electric Lawnhog...
Freezer and fridge stop working when home temp is cold
ketner1 what you are looking for is an old style freezer. They ran so hot that they didn't care what the temps in the garage was. Here is a suggestion. I am not sure what kind of freezer you have had, but look for one that doesn't have a coil on the back of it. Freezers with the condenser in the cabinet work well at the temps you are looking for, however they don't work well in garages at 90 degrees, then they just transfere the heat to the inside of the freezer. This is the style my parents use and theirs is in a storage shed with no heat.
Feb 02, 2008 | Freezers
Frozen
ok " could heat tape the water lines comeing in.
works on pipes for winter
Jan 22, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
