Question about Panasonic KX-TG5631 Cordless Phone
My phone isn't communicating with the base...HELP!!!!
My phone fell last nigh and the battery fell out so i put the battery back in and it worked. So the next day I came home it's not working, i try to fix it but it's not communicating with the base. Someone help me please!!!
  • Anonymous Jan 17, 2008
    Handset stopped communicating with base. Then battery died.
    Replaced battery. Worked fine for 1 day then...not communicating with base.
  • bravo91 Apr 24, 2009
    I keep getting a "system is busy error". Phone was never dropped or mishandled. The battery is fully charged.
Its time always become two hours early than actural
Posted on Jan 19, 2008
Why do my VTech phones says outer range or no base on both of my phones
Out of range OR No power at base is shown in the handset ...
www.vtechphones.com/support/.../353
VTech Communications Inc.Out of range OR No power at base is shown in the handset display window. Why don't ... Tip 1 of 5. Confirm proper installation of the telephone base and charger power adapters, and handset battery. You should only use the VTech power adapters provided with your telephone. ... Next Tip This solved my problem. Tip 2 of 5.
FAQs - VTech Communications
www.vtechphones.com/.../frequently-asked-...
VTech Communications Inc.Have a question about VTech cordless phones? Visit our ... How do I find my model number ... My battery pack does not last very long between charges.
VTech CS6429-4 DECT 6.0 Expandable Cordless Phone ...
Jan 08, 2016 | Vtech Lands Phones
My vtech phone displaying out of range or no power on base
This indicates the phone can't make contact with the base station. Please check if the base station is working, and has a phone line. (Perhaps you have a second phone that works well?)
If the base station works, remove the battery from the phone and put it back again. Eventualy replace battery, if you already noticed the battery did not last for more then just one call.
Jul 08, 2014 | Lands Phones
I purchased my Samsung galaxy 4 approximately 4 months ago and haven't had any problems until now. I went to bed last nigh t with my phone working. The last thing I did prior to going to sleep was to set...
First I would try taking the battery in and out, and maybe even blow where the battery connects to the phone. If that doesn't help, you might have to try buy a new battery, if it is the battery that is dead, though it might not be the problem. I would suggest going to someone who can repair your phone, or where you bought it if you have a guarantee.
Aug 22, 2013 | Samsung GALAXY S4
I get Warning! use rechargeable batteries only. But they r rechareable, and changing them doesn't help
Reboot the base :
-Make sure the handset is HF and not on the base.
-Disconnect the base from the power supply and remove the batteries (only the base's, don't remove the handset:s batteries), soon, after a few seconds at most, the handset not finding the base when scanning for it, should go off by itself.
-Wait a moment (60 sec should be plenty) then reverse the last step (batteries+power-supply).
When reboot is completed (watch for the normal screen on the LED display) just put the handset back on the base again, 'voila' !
Sep 04, 2011 | AT&T E5965C Cordless Phone
Help.....Hi my phone battery icon is red, the phone has been plugged into charger all nigh but it is still on the last little battery line and when i plug it in it's red???
Possible that your adapter is faulty and so you need to check the voltage on a multimeter. If there is no voltage the adapter is faulty, if not the adapter must be connected and the voltage at the terminal of the battery in the phone must be checked to ensure that the charging voltage is good.
If this is correct then the battery is a suspect. If under warranty you can stake for claim.
Jul 11, 2011 | LG Cell Phones
Our Panasonic system shows "No link to base walk closer" for any of the handsets even when 2 inches from the base. Seems the base has stopped communicating.
Often times when this happens try putting the phone back in the base unplug from the wall for about 30 seconds plug back in wait about a minute then try again. I have seen where you may need to also try unplugging the battery from the phone for a minute put it back in and place in the base. Its a communication problem with the phone to base connections and resetting the power often clears this up.
Hope this helps!
Aug 08, 2009 | Panasonic KX-TG2740 Cordless Phone
No link to base.
unplug the base and when you plug it back in
the handset should work
Dec 13, 2008 | Panasonic KX-TG2356 Cordless Phone
GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
Mar 26, 2008 | GE 28112 Trio Cordless Phone
Handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website- http://www.uniden.com/pdf/TRU8865-2om.pdf
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
Feb 17, 2008 | Uniden TRU8865-2 Expandable System...
Lost comunication
I solved this problem with a RESET of the handset. Instructions from the Philips website: Please perform a reset of your device. You will not loose your recorded data (phonebook and personal settings are being kept). 1. Unplug the mains of the base station. 2. Remove one of the batteries of each handset. 3. Put the batteries back in and re-plug the mains of the base station.
Mar 09, 2006 | Xact Communication XG2200 Cordless Phone
Panasonic KX-TG5631 Cordless Phone Logo
194 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
