Related Tags:
This problem should be removed because:
Problem with Philips 23PF5320 23 in. HDTV-Ready LCD Television
PHILIPS 23PF5320/28 No power and it keeps blowing fuse
PHILIPS 23PF5320/28
No power, plug in and blows fuse. Replaced P10NK80ZFP and still blows the fuse. Need help or a schematic.
Suggested Solution (3)
3.15A fuse is correct one, if it gets blow that means power supply board is defective and will be replaced.<br />I disagree with *<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Buldging Capacitors* idea because output chips are shorted out in power supply board and blowing fuse that does not happen with bulge capacitors.<br />Power supply board part number is </span>310432836212 and price would be around $140 or so<br /><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Thanks.<br /><br /></span>
Source: My Philips 42PF5421 tv keeps
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
May try to replace your power supply. Average cost runs $200 via Internet. Also may inspect test & replace deformed an or any bulging caps.
Source: philips model 29pt3425-79 flat screen wont switch on
power supply problem busted fuse
checked power supply board,found out one ic deffective try to look for the ic in electronic stores but was not available ic no. is...
flm323b power supply
Ok first off I have spent hours tracing and drawing the schematic for this power supply. It is the 200-PO0-MLT666A-AH. Photo....
My Philips 42PF5421 tv keeps blowing the fuse. I have tried three in as many days but pop! I am replacing it with 3amp. ANy ideas?
I have a Phillips 23PF5320
I have a Phillips 23PF5320 the power will only go to standby mode ,the green light comes on and then goes to red,I have unpluged the tv and...
I have a Philips LCD
I have a Philips LCD TV Model 23PF5320/28. How can I connect a Blu Ray DVD player to it. I have an HDMI cord attached to the DVD player,...
Tips for Helping vortex4 With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
conectar el computador al televisor philips...
Quiero conectar mi computador con el televisor para ver películas o usarlo de monitor para trabajar, el TV...
My 32PFL5403 TV has developed
My 32PFL5403 TV has developed a dark transparent band across the bottom 25% of my screen. What must be be done to fix...
i have a blue line
i have a blue line on the right side of my phillips 23pf5320/28 tv. what part do i need to replace?
i have a phillips hdtv
i have a phillips hdtv model #23pf5320/20 and there is no power. It just wont work what is the problem? Can you help me...
See all Philips 23PF5320 23 in. HDTV-Ready LCD Television Problems
Related Topics
Fix-O-Meter
561
561 people viewed this problem
- 0 people are following this problem. Be the first!
Top Philips Flat Panel Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
Sorry about above post that got messed up with unknown reasons.
I
disagree with *Buldging
Power supply board part number is 310432836212 and
Great answer Jee from one of FixYa's Great Online Techs!
