Question about Beverage-Air MT27 Beverage Cooler Commercial
Will not cool. Fan runs, have cleaned coil.
Beverage-Air MT27. Will not cool. Fan runs, have cleaned coil. Fan runs when switched on with switch on ceiling of cooling area next to light switch. I can't tell if compressor ever starts. Novice!
    President:
  • 3,433 Answers
The compressor may not be starting. Put your forehead against the nmachine when youturn it on or plug it in, You will feel the vibration of the pump. If it is not coming on, you may need a technician to what determine why it is not working.
Posted on Nov 17, 2009
Why is my Beverage-Air refridgerator running all of the time?
Door seals torn, poor air circulation over condenser coils or evaporator coil, defective thermostat, not defrosting or low on Freon.
APPLIANCE 911
Dec 15, 2015 | Beverage-Air MT27 Beverage Cooler...
What will make a beverage air mt27 not cool
Multiple reasons. Is it turned on & set. Is the fan inside & out turning fast. Is there frost on a line at the compressor Is the compressor outside cabinet s/b hot & vibrating continually. Is the condenser (attached to compressor with radiator) warm/hot & not plugged with lint etc between the fins. ?????
Jul 01, 2014 | Beverage-Air MT27 Beverage Cooler...
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
How to add refrigerant to mt27
You should check the condenser to see that it is clean. Is the compressor running? If you have a leak, putting in gas wont help. You need to look for oil on the components around the compressor, inside the cooling coil housing. Hope this helps good luck.
May 01, 2014 | Beverage-Air MT27 Beverage Cooler...
What does the overload relay look like a Beverage-Air MT27 Beverage Cooler Commercial
Normally thermal overloads have a button like appearance on the compressor. Designed to open circuit when temp has caused distortion to the bi-metal contacts. Upon cooling will close again. Disconnect power before checking continunity on the overload terminals.
Sep 27, 2011 | Beverage-Air MT27 Beverage Cooler...
MT27 has a noisy fan operation. Doesn't always make the clacking sound, tried leveling the machine, cleaned condenser coils. We bought this unit 2nd had for our church's food pantry to keep the meat cold...
There are a couple of possibilities that could be causing this. I believe it is the fan blade. One could be that bracket that holds the fan motor in places could have loose screws, which would cause vibration. Another is that the mounting for the fan motor to the bracket could be loose. Another could be that the fan blade itself is slightly bent. Check the motor brackets screws, fan mounting screws and the blades. If all those are good, making sure the unit is unplugged you can turn the fan blade by hand slowly to see if it is dragging anywhere on the shroud around the coil or the coil itself. You could slightly bend the "clacking" blade to clear is that is the issue.
Tom
Oct 08, 2017 | Beverage-Air MT27 Beverage Cooler...
I have a Beverage Air model MT 27. Coils have been cleaned and recharged with freon. Cooler will not cool below 50 degrees?
You'll need to check the back-pressure on the low-side of the system, you have a faulty compressor. If there is a condenser fan motor make sure it is running when the compressor is on.
Jan 28, 2011 | Beverage-Air MT27 Beverage Cooler...
Beverage-Air MT27 Beverage Cooler Commercial Logo
597 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
