Question about Cell Phones
I have a Boost Motorola I465 , I was charging it and died
I have a Boost Motorola I465 , I was charging it and the phone died.
The battery is ok because I chequed with another phone.
what can i do?
How do you reflash a motorola i465
go to that center you have purchased this phone from
Feb 08, 2012 | Motorola Mobility Clutch i465 Cell Phone
How do i fix my boost mobile i465 phone that wont turn on
check the battery or try to replace a new one..
check the mobile if it is charging,if it is,power button has a problem
if this 2 option doesn't work,bring it to a mobile service center near you and ask for assistance..
hope it helps...please rate me...thanks
Jun 03, 2011 | Motorola Mobility Clutch i465 Cell Phone
My phone will not charge.has not been dropped or gotten wet,just wont charge.it is the boost mobile motorrola 465.
It's either there's a problem with the charger or with your phone, probably battery. Try other charger and see if this helps. If you find out that the charger is ok, then you need to buy a new battery. You can find this online like ebay.
hope this helps.
May 05, 2011 | Motorola Mobility Clutch i465 Cell Phone
Battery died on my red i465 clutch now when i plug it up it just says i465 how do i fix this
question:have youbeen charging it just before it dies?
if so it will not be able to turn back on because of the battery memory.it remembers if u keep doing that.
Jun 09, 2010 | Motorola Mobility Clutch i465 Cell Phone
I took my battery out of my motorola i465 the other day and when i put it back in it will not work anymore when i turn it on it come up i465 and that is as far as it goes
hello,
when you take out your battery for a while, it ceases to work when you put it back in because the battery has lost some cells and is weak.
to solve this problem, try to charge the battery in the phone for some hours and try toturn it on again.
you can also use an external charger to boost the battery.
after charging, turn it on. and see what happens.
take care
May 30, 2010 | Motorola Mobility Boost Mobile...
Cell Phones Logo
196 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
