Question about OKI C5200n Laser Printer
I keep getting a Tonor Sensor error. Help!
I keep getting a K Tonor Sensor error. No matter how I try, I can't clear the problem. Help!
  • 40 Answers
You can try blowing the sensor located where the black toner sits if this does not work you will need a engineer to replace the toner sensor board.
Posted on Nov 25, 2009
We keep getting a db message no matter what buttons we push it our Samson dryer
http://removeandreplace.com/2015/12/23/samsung-dryer-error-fault-codes-what-to-check-how-to-clear/
Sep 26, 2016 | Dryers
HL-2280DW says replace toner but I already have
Just do a manual reset:-
Open the front cover of the printer
Press and release the "clear" key
Press "start", then press the up arrow until you see the number 12 on the display
Press "ok", you will see "accepted" on the display
Close the front cover, your toner cartridge should now work.
Original Brother tonor cartidges should reset automatically.
Apr 17, 2014 | Brother HL2280DW: HL-2280DW Wireless Laser...
Printer Supply Error 10.1004
This kind of error are cause for a toner cartridge, install a new HP toner, a your problem go.
Jan 12, 2014 | HP LaserJet 2840 Printer
Hi i am using samsung ml1640 printer after refiling it gives toner exausted messafe what i do to solve the problem
When the number of pages reach the limit specified in the chip it starts to give the message that tonor is exhausted no matter if it has tonor in it or refilled. Replace the chip or tonor and it would work fine.
If its the starter cartridge try following: -
Download the firmware from here http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=in&CttFileID=2238869&CDCttType=FM&ModelType=N&ModelName=ML-1640&VPath=FM/200904/20090416100856890/ML-1640_V1.01.00.83.exe
run the software and this will reset the page count to 0. Samsung printers generally do not support a refilled cartridge and thus the red light.But resetting the page count to 0 makes the printer detect the cartridge as an introductory one.
Also check out
http://www.savetoners.com/toner-products-a-services/77-free-information-how-to-refill-samsung-ml-1640-1641-1645-2240-2241.html
http://www.arbikas.com/forum/Attachments/ML1640_reset.pdf
Nov 04, 2010 | Samsung ML-1640 Monochrome Laser Printer
Smudges on pages
There are a few causes for smudges on page depending on the age and amount of copys the printer has done
1. Useing cheap refurbished tonor cartridges is the first.(try changing tonor )
2 Tonor has leaked into printer and is being picked up by paper as it passes through. (turn of printer and have a quick vacume where the tonor fits )
3 The most expensive one of the problems is the fuser unit has failed this usually mean you have done a high amount of copys and a replacement fuser unit is needed
Mar 10, 2010 | HP LaserJet 2420 Printer
The paper jam button is on, but there doens't seem to be any paper in there. I took the paper tray out and examined the underside of the printer, no visible paper jammed. I undid the back access part,...
power off printer
remove paper tray
open front panel
remove both tonor and phto conductor kit (tonor seats inside of that)
inspect inside the printer
Chances are there is a fragment of paper in the right corner near the paper sensor
replace components
restart printer
Keep me posted
Feb 01, 2010 | Lexmark E232 Laser Printer
When i try to print card it causes a paper jam all time. it used to print card but not now i feel this is a grat pity cause its a good printer. It doesnt matter which place i put card it just will not lift...
fter a clear card option has been installed in a Datacard card printer SP35 Plus or SP55 Plus, a card jam error my occur. The same error may occur when after replacing the main control board.
To clear this error the printer will need to determine the sensor type. For the printer to recycle through and make this determination, a power on test card is required using the appropriate clear or opaque card type to force the firmware to redetermine the sensor type. Each time the card is changed from clear or opaque to the other type, a power test card will be necessary to redetermine the sensor type.
For additional information about Datacard printers currently on the market, SP25 Plus, SP35 Plus, SP55 Plus and the SP75 Plus, contact our id card experts toll free at 888-485-4696.
Nov 19, 2009 | Epson AcuLaser C4100 Printer
Hp LaserJet 1000 series printer error message on front door cover and toner cartridge missing
hi..
ijust solved this issue
WHOA ...
my printer is HP 1020,, and i was printing a huge number of sheets, which USED TO GET STUCK IN AGAGIN AN AGIAN... coz, i was using a low quality damned paper..
now,, it began to gave error ,tht either the front cover door not closed , or its toner cartridge missing.
Well,, simple solution for me was (which is basic i think)
>> Remove the metallic plate on the back of the printer
>>there you 'll find , on the right side, near the socket for poer cable, a "lever" like thing, thats the lever for the "barrier" between the SENSOR... move it and u'll get an idea..
>> if its jammed ,, then free it..
(mine was stuck into dont know wht, and i freed it, and all is fine)
>> if spring adjusment is wrong, correst it(you may get idea by moving it again n again, whether it comes bbacl to its orgignal position or not...
> remore the tonor cartidge and insert it back while looking on the lever movements.... and you ll get whats the matter with it..
PLEASE note it,,, that i think,, the sensors are NEVER damaged !!! mind it.....my knowlegde says , sensors are hardly damaged ..
-----Adios.... Tauseem Omer...Ravian Kemcolian.
Nov 11, 2008 | HP LaserJet 1010 Printer
Printer keeps getting jammed no matter what
clean all sensors and make sure you have good dry stock to run through it like a heavy 28 lb paper. also check the path of the paper and see where it stops it might be at the paper tray pickup or even the fuser. try running the machin with the covers open by jamming something into the cover sensor and see where the paper stops at.
Aug 27, 2007 | Sharp AR-407 Copier
OKI C5200n Laser Printer Logo
162 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
