Question about GE Refrigerators
I have a GE fridge model TFB26PPDABB that is leaking from the bottom left on the freezer side. The bottom of the freezer is a sheet of ice. Please help
  • GE Master
  • 2,247 Answers
You have a blocked drain,melt out ice with hair dryer,then go to the back wall.on the bottom you'll see a holeyou might have to take wall off,that's where the water drains when the machine defrosts,i use a steamer to clean out the drain,it's a shark super steamer costs around 40 bucks but you can use a long plastic wire tie or something to snake through the drain line,slime builds up in the drain or a piece of food or anything could be in there,when you think you melted and cleaned the drain pour hot water in drain,if it goes down your done
Posted on Nov 17, 2009
We have a ge profile refrigerator and there is water leaking on the left side under the freezer. The inside of the ice tray has tan colored gunk on the ice and the bottom shelf of the freezer has a 1/2 in...
manually derfrost fridge/freezer,clean with bicarb only...... dry as best you can.(important) clean drain hose fill freezer from top with any spare space filled with foam in plastic bag(s)looks awful but works a treat (cheap too)invest in a freezer thermometer minus 20C IS BEST.....
Feb 07, 2010 | GE Profile 20.7 cu. ft. CustomStyle...
Ge side by s
found norcold #160107210--new #160107200-----on E-Bay ,under RV Thermostate-----thru seller---- eastcoastrv---Lexington,South Carolina
Oct 26, 2009 | GE Refrigerators
There is a large sheet of ice accumulating on the bottom of the freezer. The ice maker is in the off .
Your defrost drain hole is frozen over. Turn the fridge off. Remove the lower bin. Take a hammer and carefully break the ice sheet to remove it. Use a hair dryer to defrost the drain line in the rear of the freezer just below the back panel. The drain line is up on the back inside the drain pan,not under the ice you will be breaking in the bottom.
Sep 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side model tfx27pfx. Ice maker not
Your defrost drain hole is clogged. Turn the fridge off. Defrost the drain hole in the freezer. You will be fine until it does it again.
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge GSH22KGMA not getting cold
you need to replace the gasket on the unit . its letting in too much moisture.. the drain line may also be clogged up and holding water in the drain pan. take a piece of wire and clear the drain then poutr hot water and baking soda down it witrh a turkey baster.
Apr 05, 2009 | Refrigerators
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Frigidaire Model #FRS22WRC Side by Side leaking
Check the bottom of the freezer side is there a sheet of ice???
May 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
