Question about Casio FX-115ES Scientific Calculator
How do you enter a division problem on the calulator so that you get the answer and the remainder?
  • 1 more comment
  • rossdm1 Nov 17, 2009
    I have the manual, don't want to down load. Which example in the manual 1-120 show this problem?
    I have been waiting for someone to answer me about my question!!! How do you enter on the Casio fx-115 ES calulator a division problem with a remainder! I've signed up. You have all my information, so give me what I asked for. Thank you, I have a test tomorrow!
    Very Helpful!
  • 4,472 Answers
Here is a good example:
You do the division then subtract the integer part of the qoutient so you will arrive at the decimal part. Multiply by the divisor then you wil have the remainder.
In the example you have given
99 / 13 = 7.6......
You subtract 7 you will arrive at 0.6......
multiply by 13 you will get the remainder 8
Hope this helps. There may be a simpler way but this will get it done. Here is a link to the manual as well in case you need to reference it for any reason.
http://support.casio.com/pdf/004/fx-115ES_991ES_Eng.pdf
Thank you,
Lee
Posted on Nov 17, 2009
  • 6,831 Answers
Hello
Don't know if you still have the manual for calculator, but it describes everything in it, i use Sharp, so unfortunately i am not able to give you on hand support, but i found a link where you can download the manual for troubleshooting this problem.
Just click on the link and it will direct you to the download page.
http://www.retrevo.com/s/+Casio+FX-115ES+Scientific+Calculator
Kind regards
Andrea
  • Andrea Lock
    Andrea Lock Nov 17, 2009
    Hello
    Using the algorithm Original-Int(Original/divisor)*divisor
    First you calculate Original/divisor; See what is the integer part
    Then use the integer part to multiplies with the divisor. Finally Use the original to subtract the products.
    For example, say to find remainder when 73 is divided by 8
    So you find 73/8 = 9.125, and the integer part is 9.
    Now find 9*8=72
    So your remainder is 73-72=1
    Let me know if it helps
    Kind regards
    Andrea
  • Andrea Lock
    May be a little late but how about this method?
    Press MODE MODE 3 to enter BASE mode. Press DEC if necessary. The calculator should show d.
    Now suppose you want to find the remainder when 24 is divided by 5. You would press 24 - 24 ? 5 X 5 =
    The calculator should show the remainder 4.
    In
    BASE mode the calculator automatically performs integer division. This
    is also true on the FX-3650P/3950P and you can use this property in
    writing programs.
    Press MODE 1 to return to COMP mode.
    Kind regards
    Andrea
Reduce this tothe lowest terms 711over 22
The fraction 711/22 is an improper fraction (the numerator is greater than the denominator).
While there is nothing incorrect about this, an improper fraction is typically simplified further into a mixed number.
The whole number part of the mixed number is found by dividing the 711 by the 22. In this case we get 32.
The fractional part of the mixed number is found by using the remainder of the division, which in this case is 7 (711 divided by 22 is 32 remainder 7).
The final answer is: 32 7/22
Apr 09, 2015 | Office Equipment & Supplies
How many times does 182 go into 2332 and what is the remainder
I hope that I am in time!
Let's do it with long division first.
___12______________
182 ) 2332
182
512
364
148 <- this is the remainder
Now, let's try with a calculator.
______
2332/182 = 12.813186
To get the most accurate number, on your calculator subtract 12
_______
from this number and we get 0.813186 . Now multiply this number by 182 to get the remainder, and I get 148.
I love it when I get the same answer both ways;)
Good luck.
Paul
Mar 24, 2015 | Office Equipment & Supplies
How to find 3inverse%11
I am afraid the question does not make complete sense.
However to find the remainder of an integer division
You use the fraction [a b/c] key
Example remainder of 29 divided by 15
29 [a b/c] 25 [=]
That gives you 29/15
Press [SHIFT][a b/c] (d/c), you get 1 u 14 u 15 or 1 14/15. The numerator of the fraction part is the remainder.
Jan 07, 2014 | Casio FX991MS Scientific Calculator
How to find remainder as a solution in CASIO fx991ES
Finding the remainder from a division calculation is often referred to as using the MOD function, though this isn't available directly on the fx-991ES.
To obtain the remainder, for example when dividing 10 by 7, you can only divide 7 into 10 once, leaving a remainder of 3.
For larger numbers, eg when dividing 389487 by 31 (equivalent to 389487MOD31) the division gives an answer of 12564.09677 (on the display), however you only want the fractional part so subtract 12564 to give 0.0967741935 . This includes the lower value digits that were previously hidden. Then multiply this result by 31 which gives 2.999999999 on the display. Since the result of a MOD or remainder calculation involving integers has to be a whole number, the answer needs to be rounded to 3. If the answer doesn't easily round to a whole number, it is likely that you have gone beyond the calculator's working capacity.
An alternative method which avoids the rounding of the fractional part is to take the integer part of the first result (12564) and multiply it by 31 to get 389484, then subtract this from 389487, giving the answer of 3.
Dec 16, 2012 | Casio FX991ES Scientific Calculator
Sample of how to create a python program that will input two numbers and will ask the user of operation to perform as to addition,subtraction,multiplication or division the program should perform the...
Assuming that the input numbers are given by the user:print "Menu"print "1. Addition"print "2. Subtraction"print "3. Multiplication"print "4. Division"print "0. Quit"
a = input("Please make a selection:")if a == 1: x = input("Please enter a number:") y = input("Please enter another number:") answer = x + yprint "%r plus %r = %r" % (x,y,answer)elif a == 2: x = input("Please enter a number:") y = input("Please enter another number:") answer = x - yprint "%r minus %r = %r" % (x,y,answer)
The same goes for everything else just with different signs. Don't forget that "*" is multiplication and "/" is division. Also, for 0. Just use:
elif a == 0: quit
Sep 28, 2011 | Computers & Internet
How to solve the following algebra problem on the Canon calulator (HS-1200TS) 70/(1.8x1.8) or seventy devided by 1.8 squared
okay; it sounds like you are having trouble with the order of operations. A simple way to fix this and to ensure that you get the right answer is to multiply the 1.8 times 1.8, write it down, clear the calculator, and then do the division using the number you've written down. Sol your new equation will be 70/3.24 = 21.6049
Sep 23, 2010 | Canon HS-1200TS Calculator
How can I find the remainder of a division problem on my TI-84.
The function dies not exist in the OS's prior to OS Version 2.53 MP.
Anyway, if you upgrade the OS to version 2.53 M(ath)P(rint) you will have better handling for the fractions. You will also have a command remainder( accessible through the CATALOG.
  1. Press [2nd][0] to access (CATALOG)
  2. Press [x] to jump to forst command that starts with R,
  3. then scroll down till you reach remainder(.
  4. Select it and press [ENTER]
  5. Command echoes on main screen
  6. Enter two numbers, separated by a comma, close the parenthesis and press ENTER.
  7. You can also use Lists as arguments.
A quicker way to get to the command is to press [MATH] then right arrow to highlight the [NUM ] menu. Scroll Up to reach 0:remainder(
Jul 01, 2010 | Texas Instruments TI-84 Plus Calculator
How do i use my calulator to slove this problem .5/6(12x 6) 1/2(6x 14) I need to know how to program and use my calulator for a basic algebra class
The keystrokes you would use to solve the problem is as follows:
(I will use the / to indicate the division symbol)
.5
6
X
[( key
12
X
6
)] key
X
X
[( key
6
X
14)] key
Jun 08, 2010 | Casio FX-250HC Calculator
How to calculate 24124 mod 19937 in casio fx-991Ms calculator
The MOD function simply returns the remainder that is left over after dividing the two numbers.
In this case, its possible to see quite easily that only 1×19937 can be taken from 24124 before the remainder is less than 19937. The MOD function is therefore the same as 24124 - 19937 = 4187.
In cases that are less obvious, do the division, ie 24124 ÷ 19937 = 1.210011536[34]
[The last two digits are hidden on the display but still used in subsequent calculations].
Then obtain the fractional part by subtracting 1 to give 0.210011536[34]. Then multiply the answer by 19937 to give 4187. Assuming that you haven't cleared the screen between each section of the calculation, the screen will show "Ans×19937 [=] 4187".
May 10, 2010 | Casio FX-115MS Plus Calculator
I need solution for those questions
Here are the answers:
1. Use the MOD operator
DECLARE @i AS INT; SET @i = 0
WHILE true BEGIN
SET @i = @i + 1
IF @i % 10 BEGIN -- This is the MOD operator
UPDATE table SET Fields FROM table WHERE clause
END
END
% This is the MOD operator to find the remainder, which when @i is divisible by 10, the remainder (MODULAS) is 0.
2. You can't. Only the first and last can be defined. Any other AFTER triggers besides the first and last will fire in undetermined order.
Please rate FixYa! ThankYa! Happy db'ing.
Dec 04, 2007 | Microsoft SQL Server 2000 Standard Edition...
Casio FX-115ES Scientific Calculator Logo
49 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
