Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
I have a 53 in panasonic rear projection tv with a rainbow effict. what can I do?
    President:
  • 788 Answers
If you try to adjust convergence with the flash focus, perfect focus, (depending on the make of your set) or by manual convergence and the lines will not line up or even move. What you might be experiencing based on this symptom sounds like a convergence IC problem. But if the set fixes itself you will need to have it repaired as soon as possible if you wait too long there are several components that will fail in due time. If you want to repair it yourself or know someone that can solder components on the circuit board, you will need to re-solder the convergence IC’s. All you will need is some solder wick, a good 45W soldering iron, Acid free solder and some solder wick (this is for the clean-up of solder joints and cleaning up solder bridges.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With any Projection Television that has a damaged or interment convergence problem, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky
How do I tell if the IC’s are damaged?
When looking at the area around the convergence IC’s you see some resistors that have changed colors, or you test a resistor and it no longer reads the marked value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC’s located and how do I find them?
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
I have attached some photos of really bad convergence problems; your picture may not be exactly as bad as these.
Posted on Dec 03, 2009
PT-53TW53 53 in. Rear Projection has sound but no picture
It is. And I hope you some cash set aside for this extremely costly repair.
I once had a rear projection TV and was told by the repairman that each of the 3 flourescent lamps run about $200.00 to replace.
Needless to say I did not get it fixed
Oct 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
My screen has a blue rainbow across it that pulls picture upwards projection tv 1080i
Replace Both of your STKs convergence ICs they are big black ICs.will have part numbers on them.
Jun 09, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic 53" tv pt-53wx42
your convergence ic is going bad. remove front and adjust the level of blue.
Jun 01, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Screen plays double
It is called convergence out IC failure and you need to replace 2, ICs in convergence section of TV.
If you are familiar with TV repair or can solder electronics parts in circuit board then let me know exact model number of Panasonic TV to guide you more with technical info or call local TV repair shop for repair.
Apr 24, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53wx53G 53' projection tv problem
was your tv hit hard,a non magnetically shielded speaker set on top or under it?
Nov 09, 2008 | Panasonic PT-53WX53 53" Rear Projection...
TV Picture Distorted
You need new convergence ICs Call your locally tv repair shop or find someone that knows how to work on CRT projection tvs.
Aug 29, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
I have my panasonic tv
This is a convergence problem and is either bad connections at the convergence IC or defective ICs. If you can solder, try resoldering the pins on teh convergence ICs. If that fails to resolve the problem, replace the ICs. These ICs are large black ICs attached to a heatsink and may be marked STKxxx.
Keep us posted on your progress.
Dan
Jun 18, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Cannot adjust convergence, screen has rainbow effect
You probably need to change out the semiconductors. The parts are STK392-110. There are two of them, one for horizontal and one for vertical. Search it online more.
Dec 28, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
137 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
