Question about Samsung DLP HL-P5663W 56" TV
Television problem SOLID VERTICAL BLACK BARS ACROSS THE PIX
  • 1 more comment
  • tony53 Jan 13, 2010
    Hi eagle338...,
    The vertical lines I'm refering to are solid uniformed vertical lines accross the entire pix as if you were in jail bars (black)........I'm thinking video drive minor problem..I hope for this is my personal tv...!
    Yes upon turn on and warm up ..., it will show the black vertical bars..,constantly...!
  • tony53 Jan 14, 2010
    Yes, I am experienced tech for crt tvs for years and very familiar with capacitors smd type or can (electrolitic polarized type)......
    Thanx for your help on this one
    Tony Gonzales
  • 4,889 Answers
Are they all over the screen or just on a part of the screen? ALso do these bars appear all the while or after using the tv for a while?
Please let me know this info so that we can continue with the diagnosis.
Sai.
Posted on Jan 12, 2010
  • 1 more comment
  • eagle338
    eagle338 Jan 13, 2010
    Do they appear all the while or after a while after you turn on the set?
  • eagle338
    Ok.. Looks like the DM board is faulty, but since it happens only after warm up, I think its just a few leaky/swollen capacitors. How good are your electronics/soldering skills?
  • eagle338
    eagle338 Jan 14, 2010
    Ok the DMD board, is the single large board located at the center of the chasis. It will look like the image below.
    First thing to do is to check for any visual damage on the electrolytic capacitors. Like if they are swollen, cracked or leaking. If not then I hope that you have got a tweezer equipped multimeter that can be used to check for faulty SMD capacitors.
    You may need the service manual for reference values
    http://www.service-docs.com/store/catalo...
    Sai.
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Vertical black and white bars on lcd screen
I'm not too familiar with the LG brand, but if the onscreen stuff looks fine (Volume, menus, etc.) then the panel is OK. Try a picture source other than the one you are using now (Tuner, HDMI, VGA, etc.)
1) If it's the same across all of them, then you will need to replace the main board in the TV.
2a) If it only affects one input, it could either be your video source that is bad (which means TV is OK), or
2b) that certain input port on TV is bad, which would mean you either don't use that input any more, or you replace the main board in the TV.
Sep 15, 2012 | LG M208WA 20 in. LCD TV
The printer will print a bar code but the reader will not read it. the reader reads the bar code from a second printer just fine
Sounds like there are some elements worn off of the printhead causing some of the bars to not be printed. To test, create a label that prints a thick black line or solid black box across the width of the label (assuming a 4" label). Any vertical white lines that show indicate elements that are not functioning.
You could also put one label above the other, lining up the barcodes and you'll probably see bars that are missing from the label that won's scan.
The only ways to correct the problem are to install a new printhead or move the barcode field on the label so that the missing elements fall in the spaces between the bars.
Hope that helps !
Apr 08, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Vertical bars running across tv and horizontal haziness that fluctuates
are these bars slowly moving slowly like a snake kinda thing ? let me know
Jan 31, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
No picture with Vertical bars across screen
It sounds like one of the flexes on the LCD cube has either become unplugged/ loose, (there is a gate that locks the flex in connector on the DMD board), or flex damaged. Has the TV recently been moved or strongly jarred?
Nov 13, 2007 | Zenith E44W46LCD 44" Rear Projection...
TV Bars
These are called vertical retrace lines. They are going to get worse untill you find the bad capacitor(s) or replace the vertical driver/output IC. Please, if you have not the solid state repair experience, get a pro to assist you in this repair as there are no user replaceable parts inside this set. Good Luck PLease do not forget to rate this thread.
Dec 11, 2006 | Curtis CM27002S 27" TV
Samsung DLP HL-P5663W 56" TV Logo
Jerry Greenberg
Jerry Greenberg
